Will a tb and intake from a 97 lt1 work on a 93?
Old Dec 23, 2004 | 12:43 PM
bbuice's Avatar
Is the 97 TB and intake the same as a 93?Summit sells a 92-93 tb and a 93-97 tb.There is a kit on ebay that I was thinking of buying(heads,intake,tb,rocker,setc..)it is from a 97 will this work on my 93?93 is the only chip car.no pcm!
Old Dec 23, 2004 | 12:51 PM
Z28BICOL's Avatar
Re: Will a tb and intake from a 97 lt1 work on a 93?
I believe it will work and the 93 has a pcm.
Old Dec 23, 2004 | 01:05 PM
OBE1 95Z28's Avatar
Fuel rails are different between the 93 and 97. The 97 intake has a "cut-out" to allow for the cross-over front pipe of the fuel rail. You need to verify your 93 fuel rail will fit properly. Also the PCV design is different between the 2 intake manifolds.
Old Dec 23, 2004 | 01:10 PM
G-BODYT56's Avatar
If your car is a M6 (T-56 6-Speed) car the 94-97 T.B.i will work on your 93 LT-1 intake, also if you you have the M6, you can convert to the 94-97 complete intake, long as you convert/lengthen the stock fuel lines to accomodate the REAR CONNECTED 94-97 FUEL RAILS. If you have an A4 car, the 94-97 T.B. will not have the provision for the TV cable, which the 93 uses for the 4L60 tranny. The 93 fuel rails WILL NOT work on the 94-97 intakes, nor would you want it to, or waste the time modifying it to fit. HTH's
I almost forgot, if you use the 94-97 T.B, will also have to use the IAC cover from your 93 T.B., since the 93 uses the screw-in type IAC, verses the bolt-in type IAC that the 94-97 uses. Like I said, this is only a viable option IF YOU HAVE A M6 (T-56 6-Speed) car. .
Old Dec 23, 2004 | 04:45 PM
NOMAD's Avatar
Yep, as stated, an M-6 car would be the only one worth the time converting.
93 is the b@stard year for the camaro. Uses a little 3d gen and a little 4th gen...lol
-Shannon
oldschool
Feb 9, 2016 09:21 PM
onefastgta
Mar 19, 2015 10:10 AM
LT14LIFE
Feb 9, 2015 09:35 PM
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
