stumble at cold start up (~1 min.)
Old Dec 29, 2004 | 03:48 PM
97Z-pimp's Avatar
For about the last week, when i start my car for the first time of the day it idles high (~1100 rpm) and stumbles. This only lasts about one minute and then it runs normal for the rest of the day. Even if my car sits for 6 hours and i start it, it behaves normally. It only happens after the car has sat overnight. Ideas please.
Old Dec 29, 2004 | 03:49 PM
Pasky's Avatar
Re: stumble at cold start up (~1 min.)
Weird, same thing happens to me, it'll stumble in first for about 5 minutes on a warm day. Get in the car later that day and fine. Seems to happen after I go to sleep..... I do think I have a slight vacuum leak somewhere I need to pin point.
Old Dec 29, 2004 | 10:22 PM
93transam1234's Avatar
same thing happens to me, i am guessing that it has something to do witha cam and the programming for it or maybe just the cam....i duno
Old Dec 30, 2004 | 07:18 AM
97Z-pimp's Avatar
So does anyone have a suggestion for this?
Old Dec 30, 2004 | 07:29 AM
93redbird's Avatar
TPS Sensor
Old Dec 30, 2004 | 08:12 AM
RyanB58's Avatar
Mine has the exact same symptom except it does it every time I start it, Hot or Cold. I pull up a code and I get TPS and MAF readings. Dunno if these would cause it but I am going to rplace them and let ya know what I get.
Old Dec 30, 2004 | 11:11 AM
97Z-pimp's Avatar
Please let me know what you find
Old Dec 30, 2004 | 12:33 PM
Pasky's Avatar
I think I know what my problem is, mine is either a small vacuum leak or its my valves. I hear a little bit of a louder tick on my drivers side valve cover, one or two of my rockers probably came loose.
Old Dec 30, 2004 | 01:30 PM
93redbird's Avatar
Listen everyone.. At discount they are like 15 dollars... Why dont you just go by one instead of wasting time waiting for another member to post.. if it doesnt work, it is 2 screws and 2 minutes of work.. Change it in the parking lot and drive around after 2 key cycles and 2 full throttle pushes while the key is in the on position but off. Most likely if you didnt think about this, then you need to replace it anyway.
Tim
Old Dec 30, 2004 | 04:21 PM
My94T/A's Avatar
Call me slow but 93redbird what are you talking about. What cost 15 bucks at discount. I am just wondering what you are talking about. Thanks
Old Dec 30, 2004 | 04:25 PM
Pasky's Avatar
Tim
My TPS sensor is working perfectly, don't like to throw my money away. I verfied it through datamaster, but sure, "if its broke, just throw money at it"
Old Dec 30, 2004 | 10:43 PM
97Z-pimp's Avatar
mine works perfect according to my scanmaster
Old Dec 30, 2004 | 10:47 PM
speed_demon24's Avatar
I had similar conditions, except it would barley run, for a few seconds, then to 10 minutes on cold starts. It had to be completly cold though, and kept getting worse and worse till it started running like complete ****. It turned out to be my coolant temp sensor.
Old Dec 31, 2004 | 02:08 PM
97Z-pimp's Avatar
How could a coolant temp sensor cause that?
The one on the side of the head.....or the water pump???
Old Jan 1, 2005 | 12:29 PM
Digital Designs's Avatar
the sensor on the head goes to the coolant temp gauge by the speedometer, the one on the front of the water pump tells the pcm how hot it is.
