electric water pump and weep hole?
Old Dec 27, 2004 | 02:10 PM
Inutero's Avatar
I just installed the electric WP, bolted everything up and started running water through the top of the water pump and water started comming out of the weep hole. Was I supose to plug it up or something?? why is water comming out of the weep hole?
Old Dec 27, 2004 | 02:20 PM
Hawk's Avatar
Re: electric water pump and weep hole?
dude, did you put in the freeze plug? Sounds like thats your problem, you have to take it apart again and put in the plug, doh!!
Brian
Old Dec 27, 2004 | 02:21 PM
Inutero's Avatar
Yes I put the freeze plug in... the plug that you put where the shaft came into the WP to run the mechanical parts, right?
Old Dec 27, 2004 | 02:29 PM
fesgali's Avatar
ya thats the plug. what electric wp u using?
Old Dec 27, 2004 | 02:30 PM
Inutero's Avatar
ohhhhhhhhhh ****!!!!!!!
i am lookign at pics now, we put the freeze plug in the wrong way! we put the plug in from the back of the WP instead from the front. grrrrrrr now i gotta take everything apart again!!!!!!
Old Dec 27, 2004 | 02:34 PM
fesgali's Avatar
haha...forgot to do your research
Old Dec 27, 2004 | 05:45 PM
NOMAD's Avatar
Just pull the pump off and dab some JB weld over the weep hole after cleaning. It will be much easier than trying to pull the plug and everything also.
-Shannon
Old Dec 27, 2004 | 06:04 PM
Flyin_Z28's Avatar
I would advise not using JB just to plug the hole. Go to the hardware store and get a set screw that is larger than the hole. Drill/tap the hole and thread the set screw in. Use some loc-tite or RTV to seal the set screw from leaking. Works like a charm.
Old Dec 27, 2004 | 07:04 PM
Hawk's Avatar
hahaha
atleast you know what the problem is, doh!! is right
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
