oil temp & A/F gauge install
Old Dec 29, 2004 | 11:47 AM
steves97z28's Avatar
how hard are these to install? the a/f seems like it would be pretty straight foward just got to run the wires, but i have no idea how to hook up the oil temp guage. i got them for x mas along with my white face overlays and want to install them.
Old Dec 29, 2004 | 12:40 PM
Re: oil temp & A/F gauge install
The A/F ratio gauge needs the signal from the O2 sensor wire, either pin C8 or C20 on the PCM, depending which side you want to watch. Or run both wires to a SPDT switch and be able to watch both of them. All you get is a psychadelic light show, and not much in the way of useful info though.
Is your oil temp gauge mechanical or electric?
Old Dec 29, 2004 | 02:15 PM
the oil temp is electrical. not sure if ill have to tap the pan or not.
Old Dec 29, 2004 | 02:36 PM
Hawk's Avatar
no need to tap tha pan, there is a port on top of the oil filter you can use.
Brian
Old Dec 29, 2004 | 02:37 PM
Jon A's Avatar
Here's a convenient spot to put the oil temp sender:
http://www.jonaadland.com/Z28/Mods/O...r/PICT0010.JPG
There's already a plug there.
Old Dec 29, 2004 | 03:26 PM
awsome thanx
HectorM52
Jul 30, 2017 11:46 AM
jj71787
Jan 31, 2015 10:20 PM
brentbrowning01
Dec 16, 2014 06:35 AM
ro2207
Dec 4, 2014 06:18 PM
GigaMp3z
Feb 20, 2003 02:57 PM
