CSI install, do you have to install the Diode when putting in a switch
Old Dec 25, 2004 | 09:44 AM
97s10ondubs's Avatar
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
it says install this diode, well i dont have a diode nor do i know which one that it. I hooked it up to the ignition and it works fine when the key is turned on, but i also have the switch that he recommened and dont know whether i have to go out and get that diode now.
Old Dec 25, 2004 | 10:01 AM
Hawk's Avatar
Re: CSI install, do you have to install the Diode when putting in a switch
it just keeps current from flowing back to the fuse box when your switch is ON and your car is OFF. I don't know the schematic of whats in the fuse box and the ignition schematic, but I rather be safe then sorry and get a diode before you hook up the switch. It probably won't hurt anything if you don't have it if i had to bet, but I don't know for sure, if current is drawn back thru the fuse box when the car is off and your switch is on it might not be a good thing.
Radioshack has diodes.
Brian
Jan 23, 2015 01:13 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Dec 4, 2014 11:56 AM
lbrowne
Nov 13, 2011 04:25 PM
icemonkey
Feb 5, 2003 03:53 AM
