Running guideplates w/ SA Roller Rockers!
Old Dec 30, 2004 | 07:21 AM
TransAmGT's Avatar
Can i run guideplates just to be safe w/ SA RR's? Rather be safe than sorry! I'm using Crane gold 1/6's (used)! Thanks!
Old Dec 30, 2004 | 08:00 AM
96capricemgr's Avatar
Re: Running guideplates w/ SA Roller Rockers!
One or the other do not use both, if you use both chances are high that something will bind then you would be sorry.
Old Dec 30, 2004 | 08:28 AM
Guideplates are not to be used with SA rockers.
Old Dec 30, 2004 | 08:31 AM
red 95 z28 lt1's Avatar
but you can use guide plates with nsa rockers. Correct?
Old Dec 30, 2004 | 08:45 AM
Dave89IROC's Avatar
yes, with NSA rockers, something has to guide the pushrods
Old Dec 30, 2004 | 08:59 AM
ulakovic22's Avatar
Don't mean to jack this thread, but I just got a set of used Hot Cam RR's, do I need guideplates with these rockers?
Old Dec 30, 2004 | 09:10 AM
WS Sick's Avatar
You can do it but you better have some very very nice pushrods in there or you will wear the sides quickly, and or the trunion of the rocker.
I would not do it.
Old Dec 30, 2004 | 11:46 AM
bunker's Avatar
SA rocker lines up perfect with the valve, the guideplate may steer the pushrod off coarse slightly, however put it all togheter, if the pushrods clear the guide plates then you can definetely use them.
Old Dec 30, 2004 | 12:14 PM
stereomandan's Avatar
The roller rockers that come with the Hotcam kit are Self Aligning, so you do not need guideplates with them.
Dan
Old Dec 30, 2004 | 12:38 PM
TransAmGT's Avatar
The reason i asked this question is becuase the RR's i bought are SA but the part the keeps the RR's on the valve is kinda worn down! What should i do about this? Not worry about it or what? Here are some picstures of what i'm talking about!
http://img63.exs.cx/img63/8017/cam0128rn.jpg
http://img63.exs.cx/img63/1469/cam0152qj.jpg
I put one on the rocker stud and it doesn't seem to slide back and forth on the tip of the valve! You think i'll be ok with these? about 12 of the 18 look like this!
Old Dec 30, 2004 | 02:14 PM
WS Sick's Avatar
Thats very questionable, what does the rest of the rocker look like, are the trunions loose? does everything move freely?
Do the roller tips roll or drag?
can you rotate the side washers on the tip to where the better part rides onthe bottom?
Old Dec 30, 2004 | 02:26 PM
I'd buy some new rockers.
Old Dec 30, 2004 | 04:12 PM
TransAmGT's Avatar
I'm just going to put these on for a while and i guess save up some money for a rebuild kit or just buy some new ones. The rest of the rocker looks fine just a couple scratches here and there...i didn't know they were messed up when i bought them.
Old Dec 30, 2004 | 06:30 PM
SStrokerAce's Avatar
Actually even if they line up DON'T EVER USE THE TWO TOGETHER. Those things do odd things in there when they are opening and closing the valve 50 times a sec. Running them together has a very high chance of breaking a pushrod down the road, might not happen right away but it's going to be ugly.
Old Dec 31, 2004 | 03:29 PM
arnie's Avatar
Another one of those thread topics that has been beat to death. Either to lazy to do searches, or it just is not sinkin' in. Then, to top it off, bad/inaccurate info continues to be passed on/posted from thread to thread. As to the original poster, you've been had. Deal with it. Either rebuild them, or scrap them. Use them, then you deserve what you get. You acquired a worm/bad set of rockers. Sometimes, being 'blunt' is the better approach, when it comes to advice. Wouldn't be surprised if the goof you got them from, had run them with guide plates. You can lead a horse to water.....
