car feels weird after I reprogrammed for gears
Old Dec 30, 2004 | 04:32 PM
SLeeper94Z's Avatar
I installed 373 gears, about a year ago never adjusted the pcm for it until today
well i used tunercat to program the gears,The car acts like it has a high stall converter in the car, is this normal feels more torqueier down low too, It acts like the tranny slips before the car shifts , but just after i programmed it. Did i do this right or did i do something wrong ? any help will be appreciated. thanks
Old Dec 30, 2004 | 05:05 PM
Re: car feels weird after I reprogrammed for gears
I guess you would have to detail exactly what you did in the re-program for anyone to try to figure out if you did it correctly. You could always flash it back and see if still acts odd to you.
Old Dec 30, 2004 | 08:04 PM
SLeeper94Z's Avatar
All I did was change The tire size to 245/50 r16
and change the gear ratio to 373
is there a noticeable affect when you program in for gears
or does it just fix your speedomoter for you?
Old Dec 30, 2004 | 08:13 PM
Pasky's Avatar
Maybe the shift points if its an auto?
Old Dec 30, 2004 | 08:17 PM
Dave89IROC's Avatar
yeah, it would have changed the shift points back to the stock rpm/vss/tps, not with the incorrect vss reading(would have shifted low speed)
Old Dec 30, 2004 | 08:21 PM
SLeeper94Z's Avatar
Its an auto, So does anyone know what else I have change tps, vss etc?
jj71787
Dec 30, 2014 02:15 PM
cmdeshon
Dec 12, 2014 10:51 PM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
