Whoa, 100psi of fuel pressure! Cause?
Old Dec 29, 2004 | 12:46 PM
Gos2Slo's Avatar
Hey all, I had my car towed to the dealer because it cranks and won't fire, and the dealer tells me that the rail shows 100 pounds of pressure and the engine is flooded.
What would cause that? I pulled the vacuum line off the regulator the other day and it was dry, no fuel in it. The filter and pump are less than 6 months old, is there something possibly clogging up the regulator or the return line off the rail? How do I diagnose the cause?
Thanks,
Chris
Old Dec 29, 2004 | 01:10 PM
ChevyTuffD.A.'s Avatar
Re: Whoa, 100psi of fuel pressure! Cause?
It sounds to me like maybe the Fuel Pressure Regulator isnt functioning right. Anyone else??
Old Dec 29, 2004 | 01:15 PM
slimdawson's Avatar
Definately sounds like a fpr or stopped return line(never seen one). I wasn't aware that the stock fuel pump could even produce 100lbs of pressure but that would definately flood the car.
LPEdave's Avatar
I know when I installed an aftermarket pump, it pushed the pressure up by 5-6 psi, through the stock FPR. I swapped in an AFPR to back it down. But 100psi? Ouch!
Dave
Old Dec 29, 2004 | 04:28 PM
meengreen 94z's Avatar
Yeah sounds like your fuel pressure regulator is stuck closed, your FPR vacuum line is off, cracked, or clogged, or your return fuelline is blocked or kinked/bent shut. You can try to see if the regulator will open with a hand vaccum pump if you have one(fuel pressure should go down, other wise its bad). Your fuel pump can build up pressure that high at idle if it has no where to send that much fuel, you can seriously damage certain components in your fuel system though so I would reccommend repairing it before you drive it again.
Old Dec 29, 2004 | 05:39 PM
slimdawson's Avatar
Put the stock fpr back on and see what happens.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
