LT-1 Block
Old Dec 28, 2004 | 01:02 PM
cjksflorida's Avatar
LT-1 Block
I'm in the middle of putting my block back together and there is a spot right above the oil filter bracket on the block on the drivers side that is threaded, there is actually 2 of them but one has a bolt through it already, what goes in the other one that is right above that one, is a sensor or is it just another bolt. Any help on this would be greatly appreciated. Thanks in advance.
Old Dec 28, 2004 | 01:19 PM
OBE1 95Z28's Avatar
Re: LT-1 Block
The second one (furthest from the oil filter) is not used and does not get a bolt. The first one, with the bolt, is a source for pressurized oil and is used to feed oil to superchargers.
Old Dec 28, 2004 | 01:25 PM
Re: LT-1 Block
should it have a bolt or something in it, it looks like it runs into the block, that would cause it to blow oil out right?
Old Dec 28, 2004 | 01:28 PM
944v8inDFW's Avatar
Re: LT-1 Block
that unused thru hole is used on mechanical linkage clutch throwout pivot ball. Old school cars mainly. You will also have some extra holes near the motormount holes for old school motormounts. Makes it real easy to transplant a lt1!
Old Dec 28, 2004 | 01:33 PM
Re: LT-1 Block
so it doesn't need a bolt in it? thanks for all the help in advance
Old Dec 28, 2004 | 01:43 PM
944v8inDFW's Avatar
Re: LT-1 Block
no bolt needed
Old Dec 28, 2004 | 01:53 PM
Re: LT-1 Block
thanks
Old Dec 28, 2004 | 02:02 PM
ejfagala's Avatar
Re: LT-1 Block
The first hole is used on Corvette's for the oil temp sending switch and the other is not used.
Old Dec 28, 2004 | 02:10 PM
Re: LT-1 Block
The oil passage is used for the oil pressure sensor on early model 4th gen f-bodies.
Old Dec 28, 2004 | 02:52 PM
944v8inDFW's Avatar
Re: LT-1 Block
it is also a dandy place to run an external oil sump on if you are a road racer type
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
heus
Sep 8, 2015 12:01 PM
