View Full Version : LT1 Based Engine Tech
- Installing a new fuel pump
- Why TransGo over B&M??
- Steering wheel shaky when stopping!
- Where to get head swap gaskets for best price??
- Got $600 to spend what do I do?
- Is this normal...
- Part number for Fel-Pro Full Gasket Set?
- How much does Hooker Headers Cost?
- Buying Brakes
- which 30 lb injector?
- stupid thermostat question
- LT1 third gen
- driveshaft
- link to adjust rockers (i searched)
- Need Help With Parts
- custom made y pipe
- Who has installed a McLeod Street Twin???
- Best Tranny Pan Gasket??? (97 4L60E)
- What yr and model Caddies had the LT1?
- My scanmaster's screen is all messed up :(
- Access into engine bay on driver's side?
- Engine torque managment
- Can someone with datamaster check out my logged runs?
- What kind of exhaust are you guys runnin
- Which shift kit? B&M or TransGo
- Does anyone know the particulars of OBD2 emission testing?
- Car runs like crap!! & I think I finally know Why!!!!
- 1LE delete bracket diagram+measurements,.
- im looking for a different front bumper?
- m6 question
- Steps to diagnose an overheating prb?...
- Anyone used Hoosier QTP 27x11.5x15?
- car ideling weird
- How to make the most out of a 6000 rpm redline?
- They say My engine is FINISHED!
- Need Help. My fans don't come on.
- HELP PLEASE!! Car stalling on bad gas?
- I messed up
- Found my oil leak
- GREAT "how to pick a cam" write up for those intrested
- Need Cam advice and info...
- What gears are thicker?
- Don't waste your money on NGK plugs
- Got My Cut-out Installed
- Mufflex y-pipe supposed to be one piece?
- 91 octane with a stock LT1
- PCM reprogram
- Anybody got a link to a fuel pump install (dropping rear and tank, no cutting)???
- What slave cylender with Street Twin?
- Flowmaster or Spintech
- Unplugging one fuel injector help get thru emissions??
- lowering times with a new shifter
- What parameters does scanmaster show for OBDII?
- removing a 1995 steering wheel (airbag)
- Slp 2otl
- What size tap to chase spark plug threads???
- question about bose
- Advantage of a Digital 6
- last run on old motor
- If i can turn my flywheel that means my engine didnt lock up right
- Best header ground clearance
- Headers w/ loudmouth vs. True duals
- air compressor
- How hard to replace stock manifolds?
- Pics of my broken crank (thread started over)
- ET Streets with auto tranny and stock 10 bolt?
- Torque Rating of factory 10 bolts
- why don't people use header wrap to stop burning wires?
- Spark knock on throttle snap
- Any reason why I should just take the thermostat out this summer?
- as&m headers
- Largest emmissions legal cam for a stroker?
- Do I need to change rod nuts to new one when replacing rod bearings?
- AS&M CAI installed, one problem
- Scat 9000 Cast crank: H or P bearings?
- Need part # for door lock
- camaro interior remodel
- Best way to gain better response?
- Thermostat ?'s
- got my side exhaust on but no ground clearance
- Will I have Clearence?????
- How many had their starter die?
- How to align starter?
- toyo proxes RA-1
- Help!
- Car won't start, help please! Weather is too nice to miss out on!
- what causes a backfire during starting?
- $450 to spend on a new clutch kit, what to buy?
- Water leak??
- Holy Grip Batman!!!
- Will this valve train combo work look inside
- Can a starter motor, just die!!!!
- PCM BATT fuse
- Which aftermarket timing chain will work with a stock WP?
- Question about a reprogrammer, not HPP
- Whats wrong with my valvetrain (specifically lifters)???
- wierd driveshaft question
- Stainless steel cut out?
- Info and a couple video clips with the LTs
- Flexplate Pics
- New Summit electric water pump
- SLP Clutch
- Can some post some picture of where they mounted there tranny cooler.
- Top End Lt1 Lag??
- Random Misfire
- new fuel pump and regulator good idea?
- Grinding noises when downshifting
- 115 speedo
- Read my spark plug for me...
- 1997 Headers
- What does this sound like to you? fuel pressure stuff
- Question about Driveshaft U-Joints
- Jet Hot lt's owers inside
- Running 15w-50 over 5w-30, Pros and Cons
- No Retained Accesory Power.
- I need a hand with valve covers
- 4 Bolt Main
- Best budget 1.6 roller rockers?
- Question
- Why is this? Regarding rear end gears.
- GMPP Camshaft Question
- How much diff fluid fits in a 10 bolt?
- Where do I go to get these?
- Zexel Torsen Diff ???'s
- Pic of my broken crank for those who are interested to see.....
- Mobil 1 5qt sale at Walmart
- Weird grinding sound
- how do i change my headlight in my firebird
- Where did you get your magnaflow catback??
- How much to get a rear end installed
- Window motor woes:(
- 9" of manhood
- Rev Limiter coming in early
- loudmouth w/o cat, w/ gutted cat, or w/ high flow cat
- high squealing noise
- Which K-member?
- 160* thermo on an all stock LT1??
- Lugging the Engine...
- Gears
- Block machined for a 396, can I do a 383
- MPH or RPM?
- Tires: GoodYear Eagle GS-D3 ???
- Who has the lowest mileage on their LT1?
- 130,000 Miles...
- needed for new engine?
- Banjo-bolt seals
- Guys with lowered cars and relocation brackets
- 50k miles
- 1.6 RR's or more cam?
- lt1 race block?
- A serious question from a Mustang Guy
- which cutout?
- Starting not to like my borla catback
- ordered JH lt headers have a few question
- SBC cam vs LT1 cam?
- TPS question...
- Cam/Heads Install
- Looking for some torque specs...
- How bad should a heads/cam car run on stock tuning?
- PCM IGN Fuse... What would blow this??
- header,and tune up install this weekend,any tips?
- Unplug Computer ?
- Crappy dyno #'s need help
- 323's,Catback,n Cai Times
- Grrr...more problems...terminal steering wheel missalignment
- timing specs
- banging after weld in relocation brackets installed
- Once I get these heads on, what kinda rwhp am I looking at?
- throttle body covers
- Lowering??
- Speedometer not working
- Trans Temp gauge
- Split BLMs & KR at idle...
- What else needed?
- fuel injector wiring ?
- b&m shift kit
- Help! unknown vibration!!!
- checking piston to valve clearance
- Shifting point WOT on A4
- Brakes
- Every person who has had a high RPM hesitation break up around 4800+ share with mePLS
- Help ... Stupid distibuter question
- High Temps, Low coolant light. Need some help please.
- Rear gear ratio question.
- Need a new starter were is the cheapest
- Major LT1 Pre-Build ?'s Heads ,Cam, Bottom
- LT4 crate engine availability
- Guys with no cats..
- Clutch Ignition Safety Switch help- Shoebox!
- QUICK! Help with heads!
- hp ?Cmotorsports head/cam kits
- ignition coils?
- Sealed Beam Conversion for 93-97 cars??
- Sway Bars from 3rd gen to 4th gen???
- what hi-flow cat to get?
- Zz9 Vs. Lt4 Hotcam
- Guys with KYB or Bilsteins Or both Input here:
- Remove and Reposition Steering Wheel?
- Engine Rebuild?
- tranny turmoil
- Car is jerky under 2K
- Installing rear end gear ratio
- Will the factory I-pipe come out in one piece?
- Cheapest Hypertech reprogrammer?
- Muffler Series???
- Dyno with longtubes & CAI
- Is there supposed to be resistance...
- HELP ASAP! Why does my throttle stay barely open when the car is running???
- blinker lights
- Trans Am GT package?
- SES light went on while driving, then never re-appeared... how long is it stored?
- How long to foul plugs...
- best cat back??
- just ordered hooker catback!!!
- Car still tuggs or pulls at low throttle...
- Loud pitch screaming noise when I start the car..
- Engine Rebuild Dyno Numbers
- help, what should i do...
- Need help with intake mainfold
- Need some tech help, lifter and pushrod
- Swapped rear ends... need help with TCS and ABS
- GUys with BMR K-members and A-arms, Help please
- HELP #'s with LT headers
- How bad do a4s W/ et streets punish the factory 10 bolt
- New Dyno Numbers
- Brake problems
- Will a timing chain cover off an LT1 Impala fit a LT1Camaro?
- Thermostat Mod
- O2 not responding??
- Non-vented opti install guide?
- what to do with air pump lines?
- What sixe fuel injectors??
- Are 3.73s worth buying?
- matching cam to heads?
- valve springs for gm847 and 1.6rr
- AFPR and gas mileage
- auto headlights i dont want them.
- remove cat
- ? about TH350 swap
- Removing traction control
- Cam & Head Package for LT1
- Best place for hooker catback?
- SLP CAI Users - Rain Guard CutOut Mod
- Ground Clearence on Hooker LT's?
- how much HP is a stock clutch good for?
- How to make the stock 10 bolt stronger
- canging doors
- Changing differential fluid to synthetic, questions...
- What plugs and wires do you suggest?
- Air/Fuel ratio gauge
