PCM IGN Fuse... What would blow this??
Old May 20, 2003 | 01:34 AM
BOWTYDE's Avatar
I just blow it like 3 times in a row..... I'm looking for a short, anything else??
Old May 20, 2003 | 07:57 AM
A short in the wiring or anything connected to the circuit, including:
MAF
PCM
theft deterrent module
fuel pump relay
Old May 20, 2003 | 12:52 PM
BOWTYDE's Avatar
I couldn't find anything, now I'm thing that it has something todo with the fuel pump because when I put a new fuse it and turn the ignition to on it blows and I never hear the fuel pump prime....
Old May 20, 2003 | 12:58 PM
If the PCM IGN fuse blows, there is no PCM signal to turn on the fuel pump..... ?????
Check the MAF +12V wire very carefully. I think it is the pink one. They have been known to fail more often than you would normally expect. Check the resistance at the sensor end to see if it may be shorted to ground.
Old May 20, 2003 | 01:03 PM
BOWTYDE's Avatar
And if it is shorting to ground can I check this by just unpluging the MAF?
Old May 20, 2003 | 01:06 PM
If the pink wire is shorted to ground in the harness, unplugging the MAF isn't going to solve anything.
I also didn't mean to NOT check the fuel pump.... just pointing out that there may be something else.
Old May 20, 2003 | 02:03 PM
BOWTYDE's Avatar
FIXED IT
I unpluged both the maf and the fuel pump reply and then tried it, I narrowed it down to the MAF, I checked it wires and it turns out that the pink (12v) wire was pinched between the valve cover and head (morons at the shop ).
Now anyways.... Could I have done any damage to an MAF?
Old May 20, 2003 | 03:31 PM
Originally posted by Kuppler
FIXED IT
Doubt that it hurt the MAF. That is the point of the fuse blowing.
Nayr
Mar 3, 2023 08:34 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
