160* thermo on an all stock LT1??
Old May 20, 2003 | 11:02 AM
Jcb890's Avatar
hey guys,
im replacing the waterpump w/ the help of Mike (Camride from this Camaro board) and i am also going to replace the fan belt, radiator hoses and thermostat while im at it. should a 160* Hypertech thermostat be OK? the guy from CAP says it will cause all sorts of problems cuz it will run too cool since i am stock and have no programming. should i go with the 160* Hypertech or just get a reg. 180* thermo?
thanx,
jake
Old May 20, 2003 | 11:07 AM
1997rblckSS's Avatar
cooler is better!
Old May 20, 2003 | 11:09 AM
Jcb890's Avatar
So it will b OK to run a 160* Hypertech thermo on my stock LT1?
jake
Old May 20, 2003 | 11:10 AM
dobe's Avatar
almost everyone always gets the 160t-stat can't be too much wrong with it...
but im different i kept the 180t-stat
i didnt feel the need to go to 160
Old May 20, 2003 | 11:16 AM
Re: 160* thermo on an all stock LT1??
Originally posted by Jcb890
hey guys,
thanx,
jake
"guy from CAP" Civil Air Patrol?
You won't have any problems. Your car will still warm up and perform fine, but your cruising temp will be ~20º lower.
Old May 20, 2003 | 11:17 AM
Jcb890's Avatar
haha, no its commercial air patrol actually thanx tho, ill get the thermo then, screw him.
thanx guys,
jake
Old May 20, 2003 | 11:49 AM
teke184's Avatar
i can't resist...
how you gonna change the fan belt?
as for the 160 stat. i've had one in my old iroc and in my new camaro...both have no problems.
although the heat was a bit low when i drove the iroc to NY and got in some single digit temps...
Old May 20, 2003 | 12:18 PM
n2ceptor's Avatar
Stock here, 93Z, and I use a 160 ..... But I do live in Texas... Not sure about the North....
Old May 20, 2003 | 12:24 PM
bruecksteve's Avatar
I have it on mine (in Atlanta). The only thing I notice is in the winter time, I'm lucky to have much heat. But maybe if I go faster I can generate some friction that will generate some more heat.......
oldschool
Feb 9, 2016 09:21 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
