How to make the stock 10 bolt stronger
Old May 19, 2003 | 01:05 PM
ollie-99's Avatar
How can i make the stock 10 bolt stronger?
Old May 19, 2003 | 01:12 PM
wile2k's Avatar
Replace it with a 12bolt or a 9"
Old May 19, 2003 | 01:16 PM
ollie-99's Avatar
lol
good idea
but dont got that much cash
Old May 19, 2003 | 01:20 PM
IDOXLR8's Avatar
In all honesty there is not much you can do but buy a Eaton Posi, girdle cover and Moser axles. Your best bet would to be start saving up for a 12 bolt or 9-in.
Old May 19, 2003 | 01:28 PM
madwolf's Avatar
My advice is, don't spend your time and money on making something weak, a little less weak. With the money you'll invest in making it "a little less weak", you'll be halfway to getting a 12 bolt. Just wait until this one breaks, then deal with it when you have to.
Old May 19, 2003 | 06:36 PM
my94blackz's Avatar
Ok we all know a 9in or 12 bolt is stronger but that wasnt the question. The only reason im saying something cause im prolly gonna do the same thing. Where is the cheapest places for the "beef up" parts and best name brand, and what are the parts to get?
Old May 19, 2003 | 08:21 PM
ollie-99's Avatar
Old May 19, 2003 | 10:48 PM
Sparty7's Avatar
Detroit Locker, Moser axle shafts, girdle cover !
that should do the trick for you, but even that wont be cheap. i put a girdle cover and detroit in my truck and that 10 bolt is still standing up to the hard driven 35" muds on it. good luck.
Old May 19, 2003 | 11:59 PM
Acct 23749's Avatar
solid pinoin spacer in a must
Old May 20, 2003 | 12:10 AM
96LT14u2Nv's Avatar
first off, dont buy one of those worthless girdles. an easy, cheap way to upgrade it would be to....
buy a SLP take-out differential (www.slponline.com) $100
and weld your axle tubes.
i have tested that setup in a 350 RWHP A4 that ran low 12's. made over 50 passes so far.
a 9" or 12 bolt would be nice, but isnt needed with a A4. if it is a M6, u can do the same as mentioned above but it wont stand up to as much and a 9" will be needed at some point or another. however, i ran a 13.0 on consistant 1.8 60' times on ET streets with the above setup on a M6 and did fine.
Old May 20, 2003 | 12:26 AM
phil94-T/A's Avatar
Ollie you should buy the Mac girdle that Andy is selling..........good price, and it will do the job for now..........
Old May 20, 2003 | 12:32 AM
ollie-99's Avatar
yeah i've been thinkin about it
Old May 20, 2003 | 07:12 AM
my94blackz's Avatar
who is andy? I would like to chat bout that girtle like i said im doin the same as ollie. With 4.56s im gonna need all the help i can get!!
Old May 20, 2003 | 08:25 AM
IDOXLR8's Avatar
Wow why are you going with a 4.56?
Old May 20, 2003 | 08:31 AM
LT1derful's Avatar
I have a friend who's just had some of his rear end parts cryoed. I'm interested to see how it holds up. I think he also has an Eaton posi, and he was launching close to or at 4K RPMs on ET Streets in an M6. The motor blew from nitrous, so while it's out, he did the cryo treatment.
I'll be sure to update that once it's all back together.
