Help ... Stupid distibuter question
Got another LT1 , totalled Z28 , the engine was pulled to do some of the resto work. I bought it with basically everything off the motor. Unfortunatly the distributor was removed. The ditributor has 3 holes in it for the protruding shaft of the cam to mesh up to. However , how do i tell which of the 3 holes it needs to be meshed up with? The distrib was not marked when takin off so i have no way of figuring out which hole it was in when it was removed. However, the timing chain was on the enitre time if that helps. It is possible tho that the engine could have been cranked by the previous owner without the distributer on ... What is the easiert way to get all the timing issues rite ? I called a dealership and talked to the service department and they told me my guess was as good as theirs ...
Sergio
01-27-2016 04:27 PM
Redbird
09-14-2002 09:18 AM
