115 speedo
Old May 20, 2003 | 03:29 PM
Robert95z's Avatar
Exclamation 115 speedo
Is it possible to go from the 115 speedo to the 150 speedo and have it calibrated to the 150 speedo?
Robert
Old May 20, 2003 | 03:32 PM
madwolf's Avatar
All you have to do is just swap clusters with an 150 one. No calibration needed.
Old May 20, 2003 | 03:40 PM
Robert95z's Avatar
no kidding? i thought if i just swapped it out it would show like im going 150mph instead of 100mph
Old May 20, 2003 | 03:46 PM
madwolf's Avatar
Did it myself in fact, so I know it works for sure.
You'll also have to remove the speed limiter if you want to take full advantage of the 150 speedo.
Old May 20, 2003 | 03:55 PM
Robert95z's Avatar
madwolf, im looking at one on ebay, it says it has 82,000 miles, is that changeable to my current miles?
have a look http://cgi.ebay.com/ebaymotors/ws/eB...category=33675
thanks madwolf
Old May 20, 2003 | 03:57 PM
madwolf's Avatar
Changing the miles on the odometer will be challenging.
Easiest way is to swap the odometer unit from your cluster to the new one. Will work just fine and pretty easy to do.
Old May 20, 2003 | 03:59 PM
Robert95z's Avatar
duuuuh, im retarded and cant think for myself. thanks! lol
Old May 20, 2003 | 04:03 PM
madwolf's Avatar
This trick won't work on all odometers. The 97+ ones have to be reprogrammed with the current number of miles (as opposed to just swapping odometers) due to the digital odometer. So I wouldn't worry about being retarded if I were you.
Old May 20, 2003 | 08:28 PM
CamaroGuy22's Avatar
Do you guys know of any other place to get a 150 speedo other than ebay?
Sep 27, 2015 01:55 PM
mmf_1013
Sep 12, 2015 08:56 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
LazyLemming
Aug 29, 2015 07:36 PM
Catmaigne
Jul 14, 2015 05:17 PM
