What gears are thicker?
Old May 21, 2003 | 07:38 AM
Gripenfelter's Avatar
What gear ratios are thicker?
I heard 3.73s were thicker than 3.23s because of the difference in the number of teeth on the pinion. Is this true?
Anyone know how many teeth each gear ratio has on the pinion and ring?
Old May 21, 2003 | 07:42 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: What gears are thicker?
well they will have a smaller raduis
but thickness is independant of gear ratio...
strange seems to have the thickest gears
Old May 21, 2003 | 08:32 AM
chikn's Avatar
This is true with GM gears. My 3.73 ring gear was alot thicker than the 3.23. And it is like that because the pinion gear is much smaller in diameter.
Old May 21, 2003 | 09:29 AM
Does this make the pinion any weaker?
Old May 21, 2003 | 10:17 AM
chikn's Avatar
I dont see how it could be any weaker, the teeth thickness and contact area between both sets are the same.
Old May 21, 2003 | 10:29 AM
Time to move up to a 3.73 gear set I guess.
Old May 21, 2003 | 10:59 AM
treyZ28's Avatar
Man, you're going to love 40mph rolling start burn outs
Old May 21, 2003 | 11:27 AM
WheelmanZ28's Avatar
If u get 3 series gears designed for a TWO SERIES carries, they are actually thicker than 3 series gears for a three series carrier. I don't know if this is true with all brands of gears, but I'm pretty sure it is with Richmond and GM Motive.
Old May 21, 2003 | 12:26 PM
Dave C. '97 Z28's Avatar
Regarding the 10-bolt 7-5/8" rear...
The thickness isn't why they fail. What happens is as you increase your ratio (3.73, 4.10, etc...) the diameter of the pinion gets smaller. It's not the diameter that's the problem directly, but what happens is that because the diameter is smaller, you have less teeth meshing between the ring and pinion at any given moment. So fewer teeth are taking the load. Usually what happens is a tooth snaps off, then all hell breaks loose in there as it gets thrown around and chewed up....possible breaking the ring gear, carrier, or more depending on the speed and power of your car when it happens, and where the teeth randomly fall in there.
Luckily, in alot of instances it falls into the "tooth catcher" at the bottom, or stick to the magnet (if you have the stock cover on it). (BTW: The "tooth catcher" is what I call that little valley at the bottom of the differential where the oil seems to gather and wait until you think it's all drained out before it decides to spill out. )
-Dave C. '97 Z28
Old Sep 2, 2003 | 09:33 PM
So back to the original question then...
what is the stronger? 3.23s or 3.73s?
Old Sep 2, 2003 | 11:34 PM
ttt
Old Sep 3, 2003 | 03:05 PM
BigRich's Avatar
Richmond is supposed to be stronger than motive, but the whine above 50mph is not a myth, even if installed correctly
but the radio can cover it
Old Sep 3, 2003 | 03:21 PM
RamAir95TA's Avatar
Neither gear is stronger. They're both relatively weak.
Old Sep 3, 2003 | 03:25 PM
TreySpeed's Avatar
On permanent vacation
this is just PURE speculation-
but assuming equal rpm launches-
wont the 3.73 bring less stress since at X rpm with 3.73s you will be trying going 0-Ymph "intsantly", whereas with 3.23s you will be going to W mph "instantly" and Y < W???
Old Sep 3, 2003 | 03:36 PM
The 3.23 would be stronger because the pinion is bigger, meaning more teeth meshing.
-Dave C. '97 Z28
