Block machined for a 396, can I do a 383
Old May 20, 2003 | 10:18 AM
jimbjr's Avatar
I was planning on doing a 396, changed my mind to 383. Can the block still used? I obviously don't know much about the machining process.
Thank you
Old May 20, 2003 | 10:22 AM
twdz28's Avatar
yes, they should have bored the block 30 over so you want have a problem using it... Its the crank that makes the diffrence... 30 over, 3.85 crank is a 396... 30 over and a 3.75 is a 383... hpoe this helps ya...
Old May 20, 2003 | 10:26 AM
While the bore is OK, the oil pan rails and bottoms of the cylinder bores need to be clearanced for the specific crank/rod combination you picked. While a 383 usually requires less clearance than a 396, you need to have your specific parts checked for interference.
Old May 20, 2003 | 10:27 AM
Gripenfelter's Avatar
As long as its only bored 30 over its fine.
The 396 has a longer stroke.
You just need to swap cranks. Get a 3.75" stroke crank instead of a 3.875" stroke.
Old May 20, 2003 | 10:30 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
i think he is reffering to notching the block
yes, you can
they just cleared the block for a longe stroke so a shorter one will work fine
Old May 20, 2003 | 10:45 AM
jimbjr's Avatar
Thanks guys, I will post the progress once the build starts.
Jim
TitoPR221
May 26, 2015 12:20 AM
transam_388
Mar 15, 2015 11:53 AM
pimpss96
Feb 12, 2015 01:28 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
