which 30 lb injector?
Old May 21, 2003 | 02:55 PM
llafro's Avatar
I need 30 lb injectors. Summit lists two different ones:
Ford Motorsports-M9593B302 (are these the SVO injectors people talk about using on here?) $219
Accel-150830 (says “high impedance”, which is correct I think) $249
Which one is the right one? If the ford ones will work, then I can save a few bucks.
BRAD
Old May 21, 2003 | 03:09 PM
madwolf's Avatar
Get the Ford SVOs.
Accel injectors SUCK!
Old May 21, 2003 | 03:11 PM
wile2k's Avatar
The FMS ones should be fine. Just make sure whoever does your PCM reprogram knows that you are using the FMS 30#ers so they can adjust accordingly.
Old May 21, 2003 | 04:42 PM
llafro's Avatar
Is the 30 lb rating at the same fuel pressure as a stock LT1? If they use a different pressure, the actual lb/hr rate would be different on a LT1.
BRAD
Old May 21, 2003 | 04:45 PM
wile2k's Avatar
Different. FMS are rated at 39psi and GM at 43.5 IIRC. Don't really matter, you will need a reprog anyway for the higher flow and any decent programmer will know how to adjust.
Old May 21, 2003 | 04:52 PM
akafred's Avatar
Originally posted by madwolf
Get the Ford SVOs.
why do they suck i just got some 36lb/h accel injectors
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
