Banjo-bolt seals
Old May 20, 2003 | 09:00 AM
quicksilver97ta's Avatar
Banjo-bolt seals
How many seals should I have for the banjo-bolts (used for the cooling lines in back of heads) in a rebuild kit?
I received 4 (thunder racing kit) so do I use 2 per banjo-bolt?
Old May 20, 2003 | 09:15 AM
94Sleeper's Avatar
Yes, you use 2 per bolt 1 on either side of the cooling line.
Old May 20, 2003 | 01:26 PM
Oh man, now I realize how one head would take two seals. Thanks for the reply.
Old May 20, 2003 | 01:29 PM
All_Z_Way's Avatar
Sleeper is correct. It requires one on each side of the crossover water connector(whatever it is called).
Old May 20, 2003 | 02:16 PM
94 CAMRO Z28's Avatar
Anyone know an tricks to getting those bolts off? Last time I took the heads off I couldn't get them to budge so I just left them on.
Aaron
Old May 20, 2003 | 02:37 PM
All_Z_Way's Avatar
They are just very tight and hard to break loose. I couldn't get mine off til' I removed the heads.
Pretty hard to get to them and even harder to get any leverage on them.
Old May 20, 2003 | 03:13 PM
faded93bird's Avatar
stripped both of mine and had to take both heads off at ounce
i just hamered a scoket on em and then bought two new ones like 6 bucks from gm for both
colts0455
Sep 27, 2015 01:07 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
95mysticta
Aug 20, 2015 07:43 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
Bails098
Aug 17, 2015 05:15 PM
