what hi-flow cat to get?
Old May 19, 2003 | 07:38 PM
My95Z's Avatar
I jsu ordered hooker catback and now I am thinking I should get a hi-flow cat. I don't now if Iwanna gut it because I heard it makes the exhust sound rapsy and popy?? also it causes a smell?
if I get a atermarkte one, what one should I go with, and wha sizeis it, 2.5 in/out??
thanks a lot
Old May 19, 2003 | 07:55 PM
pennys58's Avatar
depending on the size of your pipes will determine the in/out of the cat. carsound, magnaflow are good, I think there are minute differnces between them all. Just do a search on the web because you don't need to spend 200 dollars when you can get them for 50.
http://www.exhaustproslinc.com/magpolstains.html has some pretty good deals or you could do a search on ebay. Car sound does a good hiflow and can get them there for around $50 and I believe you want with/out air. Good luck, anyone will be better than the original.
Old May 20, 2003 | 12:50 AM
Fatdog's Avatar
Cool
One of the hot rod mags did a test on em,and the catco flowed the best.Random seems to last longer though from previous posts.My02
Old May 20, 2003 | 01:17 AM
pennys58's Avatar
I was thinking of a third cat and catco was the one I was thinking of. It is a real good one too.
Old May 20, 2003 | 01:30 AM
chasmanz28's Avatar
where do you buy the catco at, any sites?
Old May 20, 2003 | 07:36 AM
My94RedZ28A4's Avatar
I Like my Carsound. You can see light through the cat, now that's a high flow! My car still sounds the same also, so I'm cool with the carsound.
Old May 20, 2003 | 09:38 AM
EviLBoX's Avatar
Someone on LS1.com flow tested several cats including Carsound, Random Tech, stock, and a few others. For the money, Carsound was the best.
Old May 20, 2003 | 10:27 AM
chasmanz28's Avatar
where can you find carsound at, is there sites?
Old May 20, 2003 | 12:44 PM
EviLBoX's Avatar
I can't think of any vendors off the top of my head, try e-mailing Carsound for the nearest dealer.
http://www.car-sound.com/
Also, here's the cat test data I was talking about:
http://www.ls1.com/forums/showthread...t+Flow+Numbers
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
Sep 11, 2015 09:44 AM
