b&m shift kit
Old May 19, 2003 | 10:11 PM
96PoloGreenSS's Avatar
b&m shift kit
I am installing a b&m shift kit in my car and would like to know if I should put in the stage 1 or stage 2. I'd like to hear your comments on what you have and how you like it . thanks, shawn
Old May 19, 2003 | 10:32 PM
Mr_Superman's Avatar
hey i did the same thing after reading about very hard shifting i decided to go with stage 1.....i did a cam and heads and headers and tuning from pcm4less and havent been able to figure out how good it is cuz my opti is now gone and i have been unable to drive it....ordering my opti tomorrow and i'll let ya know this weekend hopefully!
Old May 19, 2003 | 11:28 PM
Jake77444's Avatar
Use the B&M shift kit if you don't like your transmission and want to blow it up.
Old May 20, 2003 | 04:40 PM
how much is a trangso shift kit
Old May 20, 2003 | 08:48 PM
Jake77444's Avatar
Im afraid I wouldn't recommend that either, its contraversal. Especially the fact that ive had 2 tranny rebuilds in a year and going on a 3rd.
Old May 21, 2003 | 12:01 PM
I went ahead and am installing the b&m. I've heard stories of the trangso also. I figure a shift is going to be hard on the transmission anyway. I'll see how this one does.
Old May 21, 2003 | 12:35 PM
TS 95Z's Avatar
my tranny guy has been building high-performance GM transmissions for over 20 years and says he always recommends the kit to customers with performance cars or trucks used for towing. He also knew alot about beefing up the 4L60Es (targeting its weak points) so I trust him
Old May 21, 2003 | 10:57 PM
Jake77444's Avatar
b&m shift kit just increases the pressure I believe which is ovbiously bad for the transmission. Its not a debate like transgo, ive simply never heard anyone say anything good about it.
Old May 23, 2003 | 05:51 PM
Tires_Smokin's Avatar
wow, ive heard so many bad things about Tranny Kits.
I was about to install my B&M improvement stage 1 when I started calling around and all I heard was bad news. Same with tansgo. TransGo suppose to be a really good valvebody install but all Ive heard is garbage. So whats up with these kits.
Sounds like the kits valvebodies is disrupting the bands in the case. Putting pressure in one area of the bands any leaving low pressure in another part of the bands with is burning the tranny up. How about installing a SLP module to increase the line pressure and then get a tranny cooler and a bigger tranny pan..? Will that work..I dunno that much about trannys..someone gimee some feedback..
thanks, Pepper
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
RedLineRev
Jan 23, 2003 03:51 PM
TrouserSnake
Aug 7, 2002 12:43 PM
