valve springs for gm847 and 1.6rr
Old May 19, 2003 | 02:49 PM
cenman's Avatar
can anyone suggest a good valve spring for the GM847 cam w/ 1.6 rockers? i'm currently looking at the CC987 and CC985 springs. will either of these be enough for this cam? this is for a track car that will be spinning to 6900 RPM. my heads are able to take a spring up to 1.450" OD. any help appreciated. TIA.
Old May 19, 2003 | 07:11 PM
ChuckZ28's Avatar
I use K-800 double springs from K motion. They work perfectly with my cam and only cost $90.00. The diameter is a little too large so you can use shims but I had my heads machined for a better fit and to keep it safer .
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
