Can a starter motor, just die!!!!
Old May 20, 2003 | 06:19 PM
ishz28's Avatar
No notice at all. I went out to my car, just like normal and nothing. The power assec. work fine, with a friends help, I can hear the fuel pump turn on, I can hear the injectors prime. The opti/plugs/wires/coil and coil module are still newish. I hear the soleniod for the starter click while underneath the car. That's it, no noise other than those listed at all. Can starter, just die without waring (it's 3 years old)? Anyone have a pointers for me to do, before I break down and buy a starter? Also, if you believe it's the starter, as well, what types do you recommend. I have a 355 11:1 LT1 1994 Z28. Thanks.
Old May 20, 2003 | 06:52 PM
Use a remote starter switch or some heavy wire and at the starter, jumper between the battery terminal and the purple wire. If the starter does not work, then it is bad.
You could just have a cable loose, too.
Old May 20, 2003 | 06:59 PM
ishz28's Avatar
Thanks, What gauge wire will do ie 14? Just to get it straight (I get a little jumpy around elec.) One end on + of battery, run the other to the Purple wire on starter?
Old May 20, 2003 | 07:06 PM
I meant the battery cable terminal on the starter. 14 ga might be a little small. A junkyard trick is just to short across the terminals with an old screwdriver. If you are jumpy, you are gonna bump your head, 'cause some sparks will fly!
Old May 20, 2003 | 07:08 PM
ishz28's Avatar
Thank you, I'm sure I'll only scream for a little while. A board member, was nice enough to offer for sale, a LT4 starter. How do these rate?
Old May 20, 2003 | 07:57 PM
They are supposed to be a pretty good piece.
Old May 20, 2003 | 08:19 PM
Rodrigues's Avatar
My car did that, but the solenoid cracked of the starter.
Old May 20, 2003 | 09:24 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
assuming its not your battery, then yea. starter can just die like that
Old May 20, 2003 | 09:43 PM
neil350's Avatar
Mines did just out of the blue, went to go and start it and nothing.
Old May 20, 2003 | 09:50 PM
ishz28's Avatar
Thanks for all the info guys, I appericate it. The best part was, I was on my to an interview for a medical school I am trying to get into and it had to pick right then to die, but I guess it was better than after I got up there!! I think I'll buy the LT4 starter, then. I get to look real cool peddling my bicycle to school.
Old May 20, 2003 | 09:51 PM
magius231's Avatar
did you attempt to jump start the car?
Best thing to do is take it to your local Sears Auto Center and have them run a charging/starting system check for $9.
Old May 21, 2003 | 04:37 PM
95 Z/28 LT1's Avatar
Super Moderator
It's going to be pretty hard to drive it to Sears if it won't start.
Also, I wouldn't even take a skateboard to Sears.
Old May 21, 2003 | 08:06 PM
Rodrigues's Avatar
If you have a manual you can do a push start. It takes two people however.
Old May 21, 2003 | 08:21 PM
dogboy's Avatar
Mine died at 97,000 miles of use . Just like that fine one minute gone the next. You can pull it & have it tested at one of the auto parts stores for free. Just buy a good quality one if your keeping the car. I'm getting real wary of all this aftermarket crap out there. I have had way to many parts fail prematurlely due to low quality replacments.
HectorM52
Jul 30, 2017 11:46 AM
silvermansteve
Mar 4, 2015 05:02 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
ModdedNerd
Dec 18, 2014 10:52 PM
