Removing traction control
Old May 19, 2003 | 02:02 PM
blazzinbird's Avatar
I know this has prob been asked several times, I did a serch but with no luck. So has anyone ever removed the traction control motor, and still keep your abs? Or has anyone just reloacted it. I was to put furl rail covers on my car, but cant because of the tcs motor. Anyhelp is appreciated thanks
Old May 19, 2003 | 02:14 PM
Hoostie's Avatar
I took mine off, and still have abs. I had to get a new throttle cable, and a new cruize control box. I dont know the technical term.
Old May 19, 2003 | 02:34 PM
CamaroBoy96Z28's Avatar
I got the throttle cable # after asking the same question a while back.
It should be p/n 12550676. I dont have the cruise control cable # but still need it.
Old May 19, 2003 | 03:07 PM
So i will need a new throtle cable, and a cruize cable, but once i take power from the motor i will lose my abs
Old May 26, 2003 | 10:27 AM
Larnach's Avatar
I'm looking to do this too, I will eventually remove my ABS system, but I want to get rid of the ASR solenoid first. Also would I have to get a new cruise control setup?
Old May 26, 2003 | 10:58 AM
1fstTA's Avatar
ive already done this and as the above mentioned all you have to do is get cables from a none TCS car.
Old May 26, 2003 | 05:12 PM
Is there a way to retain ABS and still delete the ASR?
Old May 26, 2003 | 05:52 PM
i want to know that too
Old May 26, 2003 | 05:55 PM
Larnach's Avatar
Download that manual thing that was posted here last week, and you can see how to convert to a normal non ASR car, with some ECM programming, you should be able to keep ABS without a hiccup.
I found all the part numbers for every bracket in those 2 pages, if you guys want I can prolly post those 2 pages as JPEG's.
Old May 26, 2003 | 07:06 PM
Coop1's Avatar
Larnach please upload those pages cause I didn't see this. This will be good for us who want to pull this traction control crap.
Old May 26, 2003 | 10:32 PM
Larnach's Avatar
I was referring to this...
http://www.abrinoperformanceengineer...s%20Manual.pdf
Lemme know if you can download that, if not I will upload the pics.
Rod Bender
Nov 7, 2023 02:30 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
Jul 4, 2005 05:00 PM
