Flexplate Pics
Old May 20, 2003 | 04:56 PM
94ZVert's Avatar
Flexplate Pics
Anyone have pics of their stock flexplate? I just got a SFI Flywheel (TCI #TCI399573 -neutrally balanced-153 tooth) and everything looks good but the pair of holes near the outer lip. They're located differently than the picture I found on the web. I won't be able to compare my stuff until later tomorrow when I go back to the shop, but I'm really curious as to if I got the right piece. I'm hoping that this is the final piece for my stroker install. Any help would be GREATLY appreciated.
Old May 20, 2003 | 09:46 PM
Brent94Z's Avatar
Super Moderator
You say it is balanced. Is it possible the holes you are looking at were drilled as part of the balancing procedure? If so, it would make sense they are in a different spot than a different one you saw in a picture
Old May 20, 2003 | 09:53 PM
94ZVert's Avatar
I was thinking that too, but I wasn't sure if those holes were intended to line up to anything during installation. But if those holes are just for balancing purposes I should be fine. Can anyone confirm this? Thanks again.
Henson071
Dec 30, 2015 09:55 PM
realistyc
Jul 28, 2015 07:32 PM
cjamen
Jul 27, 2015 12:48 PM
alphaauto
Jul 26, 2015 04:40 PM
cmsmith
Jul 10, 2015 07:19 PM
