Will the factory I-pipe come out in one piece?
I am trying to remove my I-Pipe so I can install my cut-out. Is it possible to remove it in one piece? Because I can’t get the darn thing out.
Also, where do you guys install your cut-outs?
Thanks,
Jason
Thanks,
Jason
Yes. Unbolt the two shock bottoms, and lower the rear end while having the car frame on Jacks. This will give you enough clearence to remove it.
I had to remove the exhaust system when I replaced the fuel pump.
sleeperZ96BT
Sep 9, 2015 08:28 AM
Aug 5, 2015 08:35 AM
Henson071
Aug 4, 2015 09:32 AM
detroitmuscle
Jul 31, 2015 04:21 AM
