Car still tuggs or pulls at low throttle...
I was having a problem with the car pulling or tugging at low RPM's and low throttle. I had a TPS code but that went away with a new TPS. The car isnt tuned totally yet and is still rich. It almost feels like a miss so Im going to change the plugs...but only happens when mentioned above?
Is this cam surge? fouled plugs? too much fuel?
Its not so much a problem as much as it is annoying....
I already gave my opinion in my other thread and still think that it is cam surge. It will only go away with a really good tune. I have PCM4Less and still have cam surge. Under 2k and no throttle you will probably have jerks/tugs and gets progressively worse until you add throttle, am i correct?
Matt...I bet the extra cubes and increased compression helps yours out a little. I was under the assumption that by manipulating the timing you couldget rid of it. However, I know NOTHING about tuning
Let me know if you find a fix, although its not that bad for me - I don't expect it to drive like stock
Ryan
.Let me know if you find a fix, although its not that bad for me - I don't expect it to drive like stock
.Ryan
ro2207
Dec 4, 2014 06:18 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Ryan true, they cant drive as nice as they used too.
