Spark knock on throttle snap
Old May 20, 2003 | 09:23 PM
Chode89's Avatar
A friend of mine just got his 94' camaro back together. He has done a comp-cam and that's about it. The car idles rough and will stall after some time. The main concern is related to timing though. When you snap the throttle at idle it has pinging bad and will pull out timing. What can cause this or have any ideas on diagnosing it. Replaced Opti-spark, checked cam timing just to be sure. Any suggestions would be greatly appreciated. Thanks
Old May 20, 2003 | 09:27 PM
yorkie's Avatar
send PCM to....
PCMFORLESS.COM I had the same problem and not after he did his magic.
Old May 20, 2003 | 11:29 PM
Chode89's Avatar
The ECm can't handle a cam change? I realize the power potential may be a little less, but it pulls out 20 degrees of timing snapping the throttle.
Old May 20, 2003 | 11:34 PM
yorkie's Avatar
All I can say is...
I built a 383 with hot cam, etc... etc... and it ran awful, sent the pcm off got it back and it runs like a top.
Old May 20, 2003 | 11:40 PM
Chode89's Avatar
Yorkie, I don't mean to sound like I'm doubting it. I just guess I thought the ECM was a little more flexible. Thanks
Old May 20, 2003 | 11:44 PM
yorkie's Avatar
that was just...
my experience, I was bummed out bad and very let down after I got it fired up and drove it, then sent the pcm off and OH MY GOD what a difference.
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
