Loud pitch screaming noise when I start the car..
Old May 19, 2003 | 04:41 PM
96z's Avatar
96z
When I go to start the car there is a high pitched screaming noise. I was thinking maybe the belt was slipping but it only does it when I start the car and while holding the key forward. My next guess of course is starter...but is that a sign of a dying one, etc?
Any idea what could be wrong?
Old May 19, 2003 | 04:45 PM
PatriotTA's Avatar
Does it stop when you release the key while starting up? If it stops when you let go of the key, you are holding the key too long. Otherwise, it sounds like the starter interfering with the flywheel. Check to make sure its not loose.
Old May 19, 2003 | 04:59 PM
96z's Avatar
96z
Im defenitly not holding the key too long. It happens from the moment I turn the key till I let off...Ill go check the starter..
Old May 19, 2003 | 08:07 PM
96z's Avatar
96z
Anyone?
Old May 19, 2003 | 09:48 PM
NOMAD's Avatar
Cool
Make sure the starter gear is engaging the flywheel. There may be too much clearance and it's caused the flywheel teeth to wear down and now it's spinning on each other.
-Shannon
Old May 20, 2003 | 12:05 AM
96LT14u2Nv's Avatar
my guess is your starter. make sure it is tightend down completely, i have had this problem before and that is what it ended up being.
Old May 20, 2003 | 12:43 AM
LPEdave's Avatar
Did you put an aftermarket flywheel on the car? There's a chance you need to shim the starter away from the flywheel, it could be binding up a bit...
Dave
Old May 20, 2003 | 01:40 AM
96z's Avatar
96z
No its the stock flywheel. I didnt get a chance to take a look at before I went to work and its dark out now....Ill take a look at it tommorow...hopefully Ill just have to tighten it up a little...
Old May 20, 2003 | 01:46 AM
GhostZ's Avatar
Step 1: Pop the hood
Step 2: Grab pliers or pipe wrench
Step 3: Remove cat from belts
Step 4: Close hood
Repeat as necessary.
Old May 20, 2003 | 02:09 AM
96speed's Avatar
Matt I had to shim the starter with my Street Twin. Without them I get a very unpleasant grinding noise.
Ryan
Old May 20, 2003 | 10:33 AM
96z's Avatar
96z
What exactly is involved in shiming the starter? How do you know its mating up right if you cant see anything underneathe there?
Old May 20, 2003 | 04:22 PM
96z's Avatar
96z
I just got the starter off. It was on tight and it seems like the clearence bewteen the two is fine.
hmmm
Fatdog2
Feb 12, 2015 12:24 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
jj71787
Dec 30, 2014 02:15 PM
squarehead
Nov 21, 2014 08:02 PM
