matching cam to heads?
Old May 19, 2003 | 02:54 PM
cenman's Avatar
i've always heard that you should match your cam to the head flow numbers. can someone explain this further. is there a certain formula to go by? thanks.
Old May 19, 2003 | 03:25 PM
NightTrain66's Avatar
I think most people say that meaning if you have a head that goes turbulent at .550 lift, get a cam smaller than .550 lift. In my opinion, you should get as much lift as you can (with in reason) and if the heads goes turbulent before that, get the porter to fix it.
If the port goes turbulent at any lift with in reason, you should have the porter keep that from happening. Could be the back cut on the valve, could need more shortturn work, etc. but what ever it is, fix it. A port that levels off or even loses 1-3 cfm at .600 lift is not the same as going turbulent.
The duration of the cam should be picked on the RPM you want your powerband to start/end at. The lobe seperation and ICL will affect this as well but I am guessing that your question was dealing with "lift" only.
NightTrain66
Old May 19, 2003 | 03:32 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
NightTrain66
in addition to the above, more lift will cause a higher powerband but thre are oo many variables in a cam to throw in a nutshell.
Try reading the discussions on cams in advanced tech. I am follow most now without getting a migrane, but their wealth of knowlege never ceases to amaze me
thats why i just asked someone there to "design" a cam for me. trying to do it myself was killing me
pimpss96
Feb 12, 2015 01:28 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Chris Anderson
Jan 27, 2015 08:30 AM
95chwagon
Jan 13, 2015 09:19 PM
skittlez87
Dec 29, 2014 03:23 PM
