Which K-member?
Old May 20, 2003 | 11:06 AM
dobe's Avatar
Which K-member?
Wrecked my car and dented the kmember up
so im gonna try and get a new one rather replace it with a aftermarket one.
BMR makes one and PA any others?
Which one would you all recommend
this car is basicly all street might hit the track once in a while and will keep power steering
thanks
Old May 20, 2003 | 03:45 PM
tubby's Avatar
I went with bmr and it worked fine. if your interested in a stock one i still have it also.
Old May 20, 2003 | 10:23 PM
dobe's Avatar
How much trouble was it to get installed? have to buy anything else?
any special work has to be done?
did u get the one with the motormount or without?
Old May 21, 2003 | 07:43 AM
tubby's Avatar
I got the complete unit w/ power steering. my 15yr old daughter and i changed it if that tells you anything. to swap the motor from one to the other i had a jack with a block of wood on the oil pan. this balanced perfect w/ tranny attached. i lifted the motor then rolled out the stock one swap everything to the new one then rolled it back in.
Old May 21, 2003 | 07:56 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Be sure you dont get a chromoly one for street use
Old May 21, 2003 | 08:03 AM
norcalstreet's Avatar
BMR doesn't make the chromoly K-member anymore.
Old May 21, 2003 | 08:53 AM
speedmiser's Avatar
I just received my PA kmember yesterday from Thunder Racing. 2 weeks exactly. $381 included dropshipping from the factory.
I wont be installing it for a couple of weeks, but the piece looks good. Welds look thick, solid, and uniform. Prep was only so-so though, as they didnt clean the welds very well before it was powercoated. They really should have at least hit it with a steel brush before the powercoating. I'm not really concerned about the prep though, since I dont have a show car and for the most part the k-member wont be visiable. You've got to look pretty close to see the splatter anyway.
Old May 21, 2003 | 08:55 AM
You might want to look at the stuff from AJE Engineering . I haven't actually seen a setup yet, but it looks like high quality parts.
Old May 21, 2003 | 09:01 AM
treyZ28's Avatar
ouch, pricey
Old May 21, 2003 | 09:28 AM
mongse_1's Avatar
There was a pretty good thread about K-members in the Drag Racing section. I think speedmiser even started it when he was looking for his tubular K.
Old May 21, 2003 | 12:49 PM
Serial Thriller's Avatar
Here's the thread.
Old May 21, 2003 | 01:42 PM
dobe's Avatar
Thanks for the replys
Looks like i'll get the PA mild steel one.
anyone happen to have the part number for the factory kmember?
97blackformula
Aug 27, 2015 06:02 PM
Sniper33
Aug 5, 2003 09:53 AM
speedmiser
May 28, 2003 12:23 PM
Ucantcme57
3rd Gen / L98 Engine Tech
13
Oct 23, 2002 08:39 AM
ShaneS
West South Central
Sep 11, 2002 07:48 AM
