Clutch Ignition Safety Switch help- Shoebox!
Old May 19, 2003 | 08:29 PM
ZDriver96's Avatar
Ok
on the white wire i read 5.31 volts DC
on the brown wire i read .43 volts DC
I used the Metal triangle on the steering column as ground.
I was suppose to get 12 volts DC on one of these 1 of wires right???
But i tried bypassing the switch by plugging paper clip ends in the white and brown connectors and it still didnt start..??
Old May 19, 2003 | 08:56 PM
The yellow wire should have 12v on it, but only when the key in the START position.
Old May 19, 2003 | 09:23 PM
ZDriver96's Avatar
Thakns for your help shoebox.. That wire i was testing was actually a purple wire and the other was white..
Its the wrong one... all the yellow ones are are attached to large harnesses... I cant find it. I dont know what it looks like.. I dont see anything else in there that looks like it..
Im so fed up with this thing and im a moron.
only thing i hear when i try and turn it is some click in the engine bay..
Im gonna get someone over who knows what they are looking at underneath there.
Old May 19, 2003 | 09:50 PM
The switch is mounted on the clutch pedal linkage arms. There may be a couple of other connectors in the same place. Don't mess with any yellow wires with yellow connectors-those are for the air bags.
Heathen1
Jan 2, 2016 04:27 PM
timmy39120
May 2, 2015 05:12 PM
HectorM52
Jan 30, 2015 11:08 PM
Jan 23, 2015 01:13 PM
kandied91z
Aug 4, 2002 02:53 AM
