SBC cam vs LT1 cam?
Old May 20, 2003 | 02:04 AM
mastrdrver's Avatar
SBC cam vs LT1 cam?
Other then the LT1 cam has a pin for the opti, is there any other difference? Is the hole for the pin also on the SBC cams?
Jeremy
Old May 20, 2003 | 01:40 PM
Mr. Z28 73/97's Avatar
You can use any sbc cam for 86-up hyd roller just install the longer dowel pin, however make sure you get something with at least a 112 lsa or the computer and emmissions won't like it. The difference between our cams and traditional sbc cams is the nose of the cam is different to accomodate the cam retaining plate.
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Queens94z28
Nov 20, 2014 06:03 PM
rje
Sep 9, 2002 12:35 PM
