Part number for Fel-Pro Full Gasket Set?
I'm looking for the part number for the fel-pro complete gasket kit for a 93 LT1. I have searched the board and found numbers for SLP and Trick Flow but not for the Fel-Pro set. Any help would be appreciated.
Thanks,
Rob
Thanks,
Rob
Where can you find this kit? I am looking for felpro head gaskets(.39), exhaust gaskets, Intake gaskets, and valve cover gaskets. I would love to know if there is a kit out there, hopefully less than the $135 put together price. What do you think the differece is between stage 8 header bolts and arp...anything between the two that stick out? Thanks a ton guys.
JOHN
I need it for a 1997 engine.
JOHN
I'm checking out Thunder Racing, but I'm trying to see what to buy without getting duplicate gaskets...
They are GM gaskets too, not Fel-Pro.
Combination Motorsports has Fel-Pro sets...well...GM/Fel-Pro mixed.
I just want a damn complete top-to-bottom set with nothing duplicated.
Have you checked with Autozone/Advance? I got the Felpro timing kit (opti seals, cover, water pump..) from Autozone when I did my cam swap. Wouldn't hurt to check - plus no shipping charges is nice.
http://store.summitracing.com/partde...TFS%2D31400911
That's the $318 "Trick Flow" set by Fel-Pro. NO THANKS!
I need more than just a cam swap set though...I need from the throttle body down to the rear main seal, and EVERYTHING in between. 383 rebuild.
Brandon Wittmer
Dec 8, 2014 07:53 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
