custom made y pipe
Old May 21, 2003 | 01:58 PM
CM Dan's Avatar
custom made y pipe
i'm thinking about getting hooker headers cause that's what most people seem to like and they are relatively cheap too. i know you can get the mufflex y pipe but i want cats in mine. would i be better off going with a custom y or getting the mufflex y and having a shop weld some cats in? the reason i ask is in the end, i'll be look for around 550-600 rwhp via h/c and stroker and/or nitrous. i wasn't sure if a non mandrel bent y would be the best idea for flowing that much exhaust. if i do get a custom one made, what size pipes should i use?
Old May 21, 2003 | 09:04 PM
MadMaxz28's Avatar
hooker longtube headers are the way to go. the mufflex y-pipe is not. it sits too low to the ground pluss it cost to much. should cost $200-$250 to get a ypipe with cats made, the hardest part will be getting the cats to fit. if your looking to make over 400 at the wheels go with 3" pipe.
HectorM52
Jun 23, 2016 08:42 PM
Jun 6, 2015 08:27 AM
SpeedJunkee
Apr 23, 2015 09:51 AM
Apr 3, 2015 10:54 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
