View Full Version : LT1 Based Engine Tech
- What breaks in the rear end once you got the pawer to break it?
- OBD2 inspection with heavily modded 383 Stroker
- 94' LT1 in a 96' Car
- Magnaflow Cat-Back
- Ignition module or Optispark
- GAGS skip shift?
- SLP header installation kit or Stock manifold gaskets.
- Quality stroker parts??!!!
- 1.7 RR why havn't the ........
- Cant find a web site!
- motor is torquing the altinator into the A/C lines
- rubber bushings on front calipers, causing guide pins to stick
- Going from conventional to synth oil???
- Squeekin....what the *&% is it????
- Tunnel Brace? Basic Question? Help?
- H/C guys, opti keeps crapping out...
- anybody running hot cam with 1.5 rockers?
- 2 ?'s ...1 about a ram air II hood, and other about headers
- Stage 8 .750" bolts okay to use with Percy's gasket???
- building a 383 stroker
- Drop K Member/Cradle for LT Install?
- Ls1 in LT1 body
- Anybody got Borla soundclips
- Where to get GM wire diagrams for instrument cluster?
- spark plugs ( heat range)
- 986 springs
- Has anyone used this radiator?
- Will 15x12 wheels fit a 4th gen?
- 7000 Rpm Lt1
- post your vids of cammed or nos f-bodys
- How keep the car straight?
- Those who have XE cams, CC305 & 306's, please explain to me...
- Please help...
- New carpet install
- SES light on and off quickly
- TA girdle Cap Stud Kit... whats it do?
- help with pcv system please
- homemade intake makers...
- Shortest stroke?
- How do you remove the drivers side headers?
- My Spark Plug Wire Was Off!
- Will an exhaust leak wipe out gas mileage?
- O2 sensors
- Stock Gear Ratio
- Got a fuel leek, Please Help
- scanmaster install help, quick question
- AirLid for lt1?
- Why is the physical reason you cant upgrade an LT1 to have an LS1 Ignition?
- TPS Voltage reading at WOT
- CC 306 Cam install
- LT's and E-Cutout question...
- Adjustable Fuel Pressure Regulator
- P/N please
- car tries to die at stop
- Save some money, try this.
- what is this sound
- What is the difference 93 / 95 timing chain cover?
- Slight miss at low rpm
- Car died won't start, backfires
- Anyone ever weld the pinch rail to their tubular SFC's?
- Does anyone know a good place to buy BMR stuff ...
- White smoke at high RPMs
- do any of the vendors sell a complete cc 224/230 cam kit?
- how much to make a 383 stroker?
- LTCC best option?
- LT1 to LS1
- Percy's Dead-Soft Aluminum -OR- Earl's Pressure Master
- Plastic piece on the back of our seats???
- autolite104's or ngk tr 55's
- Bad ECM?
- Brand New LT1 Engine?
- Fastest way to hit 12s without heads and cam
- Paging Shoebox or INJUNEER?
- anyone running this cam
- will b body manifolds work on f bodies?
- MagnaCharger
- Get heads ported locally or go with Lloyd Elliot?
- will 2.5 in y pipe hurt with lts?
- can our cars do this?
- auto radiator in an m6
- What do you need for Y-pipe with Hooker LT's?
- Rear Caliper Anti-Squeal Plates
- cam/tuning gurus` please....
- What size are our stock manifolds?
- hose kits, goodyear hi miler, other choices?
- How much Compression can I run on Pump gas?
- Delteq Lt1 Opti-plus & Opti-direct Ignition System
- got my cam today. and im not very happy
- engine backfires and shuts off??? ***HELP ME PLEASE***
- crane ignition parts
- capacitive discharge ignitions
- Turbo DSM Injectors
- Which is louder?
- What did you do to fix your STUBBORN exhaust leak???
- Drag Radial Feedback: BFG vs. Nitto
- cam install
- Opinions concerning a 1995 Firebird Formula
- SLP vs. KB. Sub Frame Connectors
- Oil pressure went to zero!
- anyone replaced rear wheel studs?
- Convertible owners inside
- Another Cam question...
- Where to get lug nuts??
- ls1 granatelli maf on lt1?
- Where does the EGR exhaust side tube go?
- Exhaust bolts still rusted....need help
- torque converter lockup.. need help bad
- What kinda 60' can I cut?
- Where EXACTLY is the body control module on our cars?
- correct part number 4 lt4 valve covers
- Is it tough to match the quasar blue paint?
- Need Part # for LT4 intake gasket
- Differences between Comp 306 and extreme 230/236?
- Best muffler to run with loudmouth?
- 1st prob w/ the SS
- Replacing Conv Tops
- Exhaust leak
- Oil around spark plug?
- Some new pictures!
- SHOEBOX what are these???
- help me with this hub
- skip shift eliminator price?
- What size belt do I need for........
- Abs
- specs on stock cam for 97z28?
- Car failed smog. What should I do?
- jordan musser have a screen name?
- hey guys
- Cooling Issues
- Causes of running rich?
- Best cam for 383?
- When to upgrade to LT4 kock and MSD ignition
- can you shine up ceramic coated headers?
- OEM O2 sensor vs Catco O2?
- Christmas List: Which Cam?
- Question on the power option wiring
- Engine RPM Question
- best 1/4 increase cam
- whats my tire size
- carb style intake manifolds? advantage and where to purchase?
- Cam Surge?
- stock LT4 cam?
- Budget Racer
- Hey SHOEBOX....I gotta ask.
- Voiding Warranty Issues
- Modding ?'s
- SMOG w/ cc306
- what else is a good idea to buy with cam.
- How to get air bag & air pump lights off
- what MPH is the TA/formula body safe too?
- Fuel injector Cleaning
- Figured it out
- coolant leaked, sprayed all over engine
- Quick question?
- Have a engine noise need help?
- Why do i smell
- Short throw shifter
- m6 does not want to go in gear when cold?why
- back of 1 full turn and still no chatter?
- Missfire ...hesitation...
- Head job
- Torque arm mount clam shell!!!
- Ummm........Jason Cromer...nah.
- HotCam installation prices
- New lifters with cam install needed??
- tiny slice in wire???
- Part number for the Temp Sensor LT1
- Sounds like I got a Supercharger...why??
- Do I need better ignition????
- Anyone know who sells a 396 stroker kit for the LT1 ?
- 1.6rr,what springs?
- Thumbs up to Bryan at PCMFORLESS.com
- Junkyard Rebiuld, Is it worth it???
- what size cutout? i have aftermarket exhause
- GM847 cam
- 383 ?'s
- passenger side o2??
- What Head Gaskets and Head Bolts are You Using??
- subframe connectors/ torque arm???
- 383 stroker questions
- filing down 98-up rims to fit 95 Z28
- Help Me Out With Some Problems...Heads/Cam Car
- upgrading fuel injectors.........bosch or delphi/lucas ?
- need pics of shifter
- SES LIGHT GIVES 7 CODES!!! HELP! Please Read!
- Need Help A S A P !!!!!!!!!!!!!!!!!!
- Rear brake pad that stops good, no dust, no wheel hop
- pageing lt1_car
- Stock Lifters for LT4 Hotcam????
- Anyone ever hear of an aluminum LT1 block?
- is there any good spring kits taht retain stock hight?
- Headers
- Anyone wanna trade sportlines for my pro-kit springs?
- underdrive pulleys and ram air box problem
- emissions
- "EGR recirculation failure" after LT install (OBD2:P0400)
- anyone dyno with a cm 227/233 cam yet?
- winter project question
- Anyone replace brake lines w/custom ones?
- How much HP can an LT1/LT4 block handle?
- cc 306, comp 224/230, or lt4 hotcam
- Rough Idle smoothes out with cooler outside temperature?
- I need the size of the bolts that hold the power steering pump in place
- Peak Global Extended Life Coolant?
- Time for new brakes....
- Best intake for an LT1
- down shifting ion & others
- Spun Bearing maybe?
- To manual shift or not to manual shift????
- Wires touching.....
- Storage problem
- Pressure needle bounces.....
- Torque arm mount bolts.. all of them..
- Can you remove and replace the glass in side mirrors?
- Evap system experts inside please!!
- just got back from the track, some times inside
- C5 Rims on my 97 LT1 Z28, questions???
- help me Decide PLEASEE!
- Will headers really help that much?
- Is thos on right?
- Getting exhaust?
- of these 2 cams, what would you pick
- Does anyone have a cc306 or a LT4 HC???
- Setting the Valves....Big Issue
- need a little help lt1 guys needed
- Whats better and whats quieter- Resonator or Cone?
- Length of stock "vented" Cam Dowel??
- 60 ft times
- Going from LT's to Mid/Shorties
- Bad Vibration
- cc 306 without tuning
- sorry its another lt header question
- Should I get mid's or LT's? Please Help!!!
- SLP Loudmouth for LT1
- i have a 94 will a 95 opti just go on or what do i need
- car wont start....
- Anyone ever use glasspacks?
- Air Bag light is on all the time.
- Best Exhaust to Get.
- Installing Scanmaster on 97 SS w/ OBDI?!?!?
- Opti-Spark Question??
- Welding stock rear end axles to pumpkin?
- PLEASE HELP ME!!! Car STILL runs like crap and nobody knows why!
- passing smog without a cat?
- what's the difference?
- where to buy an opti
- SLP Loudmouth VS Magnaflow
- What do I do now?
- o2 location??
- shoebox, and those with experience
