Stage 8 .750" bolts okay to use with Percy's gasket???
Old Dec 6, 2003 | 11:10 PM
96 WS6's Avatar
I remember reading that somebody thought that the stage 8 bolts were too short to use with percy's dead-soft gasket... I like the fact that the stage 8's have the allen screw. I'm thinking about getting ARP 1" long 3/8 hex head bolts but I will hold off if the stage 8's will work.
I need a quick answer, are stage 8 bolts okay to use with Percy's dead soft aluminum gaskets (thickness wise).
Old Dec 6, 2003 | 11:15 PM
madwolf's Avatar
Arrow
I have Percy's and Stage 8s, but mine are 1" long.
I think you'll be ok with the 3/4 ones but it will be close...
Old Dec 6, 2003 | 11:20 PM
96 WS6's Avatar
Do they make 1" stage 8's??? How close will I be cutting it. I don't want any more freaking exhaust leaks. I'm absolutely sick of it.
Old Dec 6, 2003 | 11:22 PM
anaik's Avatar
Get nothing less than 1", 1 1/4' will probably work better. You have to remember the header flange is 3/8".
Old Dec 6, 2003 | 11:24 PM
96 WS6's Avatar
I think the SLP headers are 1/4 inch flange. The bolt locations are so ****ty I need the allen aspect of the stage 8's... I'm not paying 40 bucks for some stupid bolts that cost 2 cents a piece. If I get any they will be the 1 inch black oxide ARP's.
http://store.summitracing.com/defaul...part=760-66031
Old Dec 6, 2003 | 11:28 PM
anaik's Avatar
The black oxides will start rusting, get the stainless steel.
Old Dec 6, 2003 | 11:29 PM
madwolf's Avatar
They sure do make 1" long ones.
Thunder Racing
Scroll down to the bottom of the page.
That's what I have.
I didn't try 3/4s myself, but I've read someone saying that they did.
Old Dec 6, 2003 | 11:30 PM
Z95m6's Avatar
I have percy's with 3/4" stage 8 bolts. They were a PITA to install but i got it done. You can only get the bolts to barely catch the threads so you have to snug them up one at a time constantly working the header down evenly so you don't put to much stress on one bolt. If i would of thought ahead about how thick the gaskets were i would of gotten 1" bolts.
Old Dec 7, 2003 | 12:02 AM
96 WS6's Avatar
I think I may just use the stage 8's I have now and then when I end up doing an engine/heads in the future, replace everything with ARP's including the header bolts.
Old Dec 7, 2003 | 06:17 AM
DB75's Avatar
I have the Percy's and 3/4 Stage 8's myself. It will work but your better off with the 1 in. bolts.
DB75's Avatar
Old Dec 7, 2003 | 10:13 AM
Bud M's Avatar
I'm running 3/4" Stage 8s with no problems.
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
97 RedSS
Jun 10, 2003 07:58 PM
