how much to make a 383 stroker?
Old Dec 6, 2003 | 09:08 AM
matto1225's Avatar
i have a stock lt1 right now, considering over the winter making it into a stroker, most of the work myself, besides boring and stuff like that of course, how much would it cost about to do the whole deal? thanks!
Old Dec 6, 2003 | 09:22 AM
Larnach's Avatar
Forged? Cast... lightweight components?
Anywhere from doing a hackjob for $1500-2000 to an all out high end, lightweigt components, etc. etc. of around $6000 for the shortblock.
Old Dec 6, 2003 | 09:26 AM
Mike383LT1's Avatar
stroker
i bought an eagle rotating assem. when i did mine cost around 1500.00 comes with crank,rods,pistons,brgs,rings your going to have machine work and gaskets possibly a cam would not run stock stick would recomend a good timing chain when i had mine done i had my block converted to 4 bolt with splayed caps i paid 4900.00 for mine that also included a valve job on my cnc heads also had mine converted to an internal ballance so many options i would recomend you talk with a decent machine shop and see what they recomend but i would guess anywhere from 3000.00 to 5000.00
Old Dec 6, 2003 | 09:29 AM
gb95zconv's Avatar
As little as $1800 depending on your current setup(what will you use from it) all the way up to $4000+ . Need more info on your goals for the engine and such to say for sure. Mine ran about $2300 total but I allready had the cam ,the fuel injectors, ported heads, a 52mm TB, and 1.6 rr.
Old Dec 6, 2003 | 10:36 AM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
Cam and head work are going to be the most important thing to any combo, so don't be cheap in that department. Of course when upgrading the motor, your going to need to do the rearend aswell, as that will be your most limiting factory.
Old Dec 6, 2003 | 10:44 AM
S.J.S.'s Avatar
Dude....from the look of your sig., you aint got too much mods on there. I just did mine and its a snowball my man. You stroke it and you need to do everything else to make it work. Ex.: injectors....programming......TB...Headers.....hea djob....tranny build up. By the time I was done I had over 9k in it and still aint done. And...oh yeah....I did everything myself aside from the block work.
Old Dec 6, 2003 | 05:04 PM
96LT14u2Nv's Avatar
it all depends on how u want to build it. seen em cost anywhere from $1,500 to 15,000 +
that is a lot to do over the winter. u will lose driveability and NEED to do upgrades to the tranny and rear to handle all that.
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
