What did you do to fix your STUBBORN exhaust leak???
Old Dec 5, 2003 | 06:53 PM
96 WS6's Avatar
I have one BOTH sides and I have had them there since I installed these POS headers... I am using felpro 1406 with a light layer of ultra copper on both sides. I'm thinking of using percy's dead soft aluminum as I have tried many "tricks" to get them to seal and those gaskets don't want to do it. Anybody have suggestions??
Old Dec 5, 2003 | 06:59 PM
Prorac1's Avatar
i use the steel embossed manifold gaskets, if a bolt comes loose, which it does often, you tighten it up and go on your way. No more blown header gaskets. Hope this helps, prorac1
Old Dec 5, 2003 | 09:34 PM
96 WS6's Avatar
I know more people do this come on.
Old Dec 6, 2003 | 01:58 AM
92LT1RS's Avatar
Mr. Gasket embossed copper manifold gaskets. the rear bolt on the passenger side kept backing out, tighten it up, it'd seal till it loosened up again. Finally was able to get the bolt tight enough not to back out.
Old Dec 6, 2003 | 03:44 AM
96 WS6's Avatar
http://store.summitracing.com/defaul...611+&x=13&y=14
Those are the ones I was thinking of picking up... do I need to clean the surface of the head/header? Last time I had to replace the gaskets I inspected the surface and from what I saw there was no debris on either surface. I'm going to slap these coppers in and see how they do. Should I use RTV on them or just put them in as is?? I'm thinking as is right?
Old Dec 6, 2003 | 03:45 AM
97WS6SCharged's Avatar
Breslin splitlocks. Nuff said.
Old Dec 6, 2003 | 03:59 AM
96 WS6's Avatar
And what might those be??? Are they those bolts with the locks you tighten down??? Am I missing something???
Old Dec 6, 2003 | 04:44 AM
hvyss's Avatar
I use Earl's performance header gaskets and have never had a leak. I even had three bolts come out of the driver side header and had no leaks. I'm sold. Call Summit. They have them in stock. The part number is EAR-29DA3B. Cost is $44.44 with shipping. Good luck
HVY SS
Old Dec 6, 2003 | 05:05 AM
Think of them as polylocks for your headers.
http://www.ecklers.com/product.asp?d...60&pf_id=45263
This is the only link I found with a decent picture, but you can probably find them at your local hot rod shop.
Old Dec 6, 2003 | 05:38 AM
96 WS6's Avatar
HVY SS
I had those before and I could not even get them lined up without the center soft metal coming out and they were very flimsy. They do not have hooked ends either...
Old Dec 7, 2003 | 06:29 PM
arnie's Avatar
Re: What did you do to fix your STUBBORN exhaust leak???
POS headers? Do you want a fix for the problem, or a 'band-aid'? If the problem are the headers, straighten or repair them.
Old Dec 7, 2003 | 06:37 PM
96 WS6's Avatar
There's nothing wrong with the headers, they are POS because they are known for having sealing trouble and because they **** me off...
Remember I am from CA. If I knew at the time I got my headers that my car would be supercharged and cammed with a big *** cam I would have just got long tubes but that will have to wait now.
I'm ordering Percy's dead-soft aluminum gaskets AND ARP 1" 12 pt. bolts
Magenta_Hearts
Mar 25, 2015 10:24 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Brake_L8
Jan 20, 2015 09:44 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
MislMan
Jul 19, 2002 11:41 AM
