Fastest way to hit 12s without heads and cam
Old Dec 6, 2003 | 12:02 AM
formula king's Avatar
i was wandering what is the best and most proven way to get an lt1 m6 run mid-high 12s all day...........on stock heads and cam.....
or heads and stock cam or maybe A/m CAM and stock heads
Old Dec 6, 2003 | 12:03 AM
97WS6SCharged's Avatar
Forced induction or N2O.
Old Dec 6, 2003 | 12:39 AM
Zack's Avatar
and you might wanna shorten your sig. 5 lines or less. do it before a mod does it themselves
Old Dec 6, 2003 | 12:42 AM
93formula's Avatar
wieght reduction, slicks. skinnies, n2o, gears, torque convertor if you have an auto. all bolt ons.
Old Dec 6, 2003 | 12:45 AM
Vortech=bolt on.
Old Dec 6, 2003 | 03:12 AM
formula383's Avatar
NX
I had an NX kit on my Z28 with only a CAI, 3.73 gears and a 150 NX shot I ran a 12.2 @ 115
Old Dec 6, 2003 | 03:58 AM
hvyss's Avatar
Nitrous
Old Dec 6, 2003 | 07:48 AM
He said the best way to run 12's all day, nitrous is done after a few passes.
Old Dec 6, 2003 | 09:24 AM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
Unless you have a couple of bottles. I have 2 10lbs bottles and one 15 pounder. It's always good to have backups when using NOS. You don't want to give the common excuse that you ran out of nitrous, and that's why you lost, or didn't run a good time at the track.
Old Dec 6, 2003 | 09:29 AM
Mike383LT1's Avatar
12's
check out gm high tech they are going to try to do it without touching the valve cover's all bolt on's i think they did it the article is called the grapes of wrath
Old Dec 6, 2003 | 10:52 AM
CANTONRACER's Avatar
I guess some of you missed the part about "fastest way"....simply no way faster than an n2o kit for the amount of time it takes to install compared to the power it generates.
Old Dec 6, 2003 | 11:11 AM
Derrick Redd's Avatar
NX wet kit.
Old Dec 6, 2003 | 11:21 AM
lt1camaroman93's Avatar
if its an auto.. stall/gears/headers/drag radial.. pull some weight and you are deffinatly there.. I had that setup and made it to the 12's on bolt ons.. didn't even take the valve covers off to get there.
Old Dec 6, 2003 | 12:44 PM
what are the best bolt-on besides full exhuast and gears that make a big diffrence
Old Dec 6, 2003 | 12:59 PM
Bad AZz Z28's Avatar
for what its worth I/H/E, drag radials and a hotcam kit on stock heads did it for me
