GM847 cam
Old Dec 4, 2003 | 06:31 PM
94_Camaro_LT-1's Avatar
GM847 cam
Anyone know where I could buy this?? I know gmpartsdirect.com has it but I only entered in the part number and got a description of "camshaft" and their price... I think the specs I found were 234/242 112LSA Thanks guys!!
Old Dec 4, 2003 | 06:36 PM
LPE Z convt's Avatar
Do a search under the name Jason Cromer he can help you out and save you$ 234/242 575/595 with 1.6 roller rocker
Old Dec 4, 2003 | 06:37 PM
QCKZ28's Avatar
paceparts.com
jason chromer
any gm dealer (not recommended)
gmpartsdirect.com
cmotorsports.com can get it for you.
crane has the exact same cam, under a different p/n
hope this helps
jesse
Old Dec 4, 2003 | 07:14 PM
How bout with 1.5s? I have the CC race anodized gold rockers... what would thel ift be with those? I know my springs will handle the 847 ... thanks guys!!
Old Dec 4, 2003 | 07:22 PM
reuter's Avatar
figure out your lift by dividing the 1.6 lift by 1.6, then multiplying that number by 1.5
the factory lift numbers on the gm cam is for a 1.5 rocker
Old Dec 4, 2003 | 07:25 PM
OK got a description from pace...
This hydraulic roller design contains eccentric for mechanical fuel pump. It is for off-road use only. The duration at .050" tappet lift (intake/exhaust) is 234/242; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 539/558. Valve lash is zero/zero and lobe centerline is 112 degrees
I cant wait!! thanks again
Old Dec 4, 2003 | 07:50 PM
twdz28's Avatar
anyone have a sound clip of this cam??? how is the vacuum???
Old Dec 4, 2003 | 08:31 PM
http://www.madz28.com/chris847.mpg
Here you go.. Vac. is fine
Old Dec 4, 2003 | 09:22 PM
formula383's Avatar
I have been considering the 847 for my car as well. I would give Jason Cromer a call he will give you a good deal on it.
Old Dec 14, 2003 | 11:50 PM
Zac2003's Avatar
whats jason cromers # so I can get a price??
Old Dec 15, 2003 | 08:57 AM
$209 plus shipping
Old Dec 15, 2003 | 11:33 AM
Zac2003's Avatar
Originally posted by 94_Camaro_LT-1
$209 plus shipping
and his phone # is??
and does he have good deals on a whole kit with rr's etc...
Old Dec 15, 2003 | 11:46 AM
Grease's Avatar
Actually vacumm is not the best. I have 11" of vacuum with ported heads and 1.5 roller rockers. Needless to say my brakes suck. Even on wet roads I have trouble getting the ABS to kick on.
I bought a vacuum canister from Summit Racing but never put it on. I'd rather go with an electric vacuum pump.
Old Dec 15, 2003 | 12:44 PM
kgkern01's Avatar
How is the midrange torque with this cam? Any dyno numbers with this on stock heads?
Old Dec 15, 2003 | 03:32 PM
Rx-7 SS's Avatar
http://web.camaross.com/forums/showt...hreadid=203498
very impressive curve to say the least.
