Where does the EGR exhaust side tube go?
Old Dec 5, 2003 | 04:53 PM
WhiteBeast's Avatar
where does the EGR pipe that connects to the intake manifold go to?
I cant seem to trace it anywhere
Old Dec 5, 2003 | 05:41 PM
Van5150's Avatar
Are you talking to the bendy metal pipping at the back of the intake manifold ?
If so the other end goes pass side exhaust manifold held on by a rusty bolt that will break off.
Old Dec 5, 2003 | 05:46 PM
Cman's Avatar
You'll probably be able to get at it by the ex. manifold side only from below, it won't be accessible from up top. It'll bolt to the side of the pass. ex. manifold just above the collector where your pass. part of the y-pipe connects to the manifold.
Once you find the bolt that connects the pipe to the manifold spray some rust penetrant on there and let it soak a bit before trying to unbolt it. You don't want to snap that bolt off or you'll be doing a manifold re & re to fix it, but if it happens, good time to think about some headers.
Old Dec 5, 2003 | 05:58 PM
WhiteBeast's Avatar
I guess i will just have to penetrate it with some serious amounts of pbblaster
HectorM52
Jul 30, 2017 11:46 AM
Chris Anderson
Jan 27, 2015 08:30 AM
Jan 5, 2015 07:14 PM
thenewkid
Nov 18, 2014 12:57 PM
Jul 4, 2005 05:00 PM
