Sounds like I got a Supercharger...why??
Old Dec 4, 2003 | 09:12 PM
S.J.S.'s Avatar
He guys....nailed my car for the first time last night. After it gets up to about 3k and on, it whistles like hell. Sounds like I got a 6 pounder in there or something. Is that normal? What causes it?
Old Dec 4, 2003 | 09:18 PM
Cmr0z28's Avatar
Mine does that from like 4500-up......I think it's just the CAI.
Old Dec 4, 2003 | 09:26 PM
ibanez6rg's Avatar
That's pretty loud for a CAI I would think, I've never heard mine that loud and to hear that over your 383. You sure you're not boosting
Old Dec 4, 2003 | 09:52 PM
ChickenScreamer94's Avatar
My did the same thing-turned out to be my accy. belt slid off the crank pulley a third of the way. Check the belt. It is isnt that then it may just me normal cam intake harmonics....i have never heard a cammed car on the inside so i am just putting a suggestion out on that one
Old Dec 4, 2003 | 10:21 PM
Larnach's Avatar
Check your p/s fluid level.
Old Dec 4, 2003 | 10:32 PM
amean94ta's Avatar
YES check the ps first if not did you replace your timing chain? If so some of the new ones are not machined "quiet" like oem gm but it is ok
Old Dec 4, 2003 | 10:41 PM
neil350's Avatar
I noticed any LT1 I have ridden in, has a good amount of power steering pump whine.
Old Dec 4, 2003 | 10:47 PM
Kain's Avatar
52mm throttle body is sucking in more air from the IAC? My BBK 52mm whistles like a supercharger (minus the blown alternator sound), and speeds up and slows down with engine speed.
Old Dec 5, 2003 | 12:49 AM
97WS6SCharged's Avatar
My car whistles too. Just can't figure out why...
Old Dec 5, 2003 | 11:36 AM
BigJustinZ28's Avatar
my slp cai whistles a bit too
Old Dec 7, 2003 | 02:54 PM
chad_g69's Avatar
My K&N FIPK sounds like a supercharger ever since i replaced the K&N filter with a bigger (longer) one that also alows air to inter from the end it it also...
makes the ricers not want to race...
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
