Differences between Comp 306 and extreme 230/236?
Old Dec 5, 2003 | 03:43 PM
Black94mula's Avatar
Is one more streetable? I have a, well look at the signature. The only other mod i will be adding is Hooker LTs. Any suggestions?
Old Dec 5, 2003 | 04:01 PM
Gripenfelter's Avatar
The XE 230/236 makes more mid range power so I'd say its more "drivable". Its less peaky.
Old Dec 5, 2003 | 04:08 PM
Does the cc 306 really start pullin after 4500?
Old Dec 5, 2003 | 04:45 PM
llafro's Avatar
When you look at the advertised (0.006" lift) duration numbers for the two cams, the difference shows up. The 230/236 XE cam has advertised duration of 282/288, while the 306 (230/244 @0.050" lift) has advertised numbers of 290/307.
So, the XE crams the same amount of intake duration at 0.050" lift into 8 degrees less total duration than the 306 (282 for the XE vs. 290 for the 306).
Total duration (and overlap) is what causes the driveability problems associated with bigger cams. By opening the valves faster, you get a cam that behaves more like a big cam on the top end, and a cam that acts more like a small cam at low RPM (To a point at least...).
The faster opening and closing rates of the XE cams put extra stress on the valvetrain and require stiffer springs. Also, because of the more severe profiles used on the XE cams, you may run into valve float sooner. So, you may wind up with a cam that drops off after a certain RPM (as many of the XE grinds seem to do). Especially on a stock bottom end, this isn't really too big a problem, since many people don't want to rev too high anyway.
So in summary, the 306 is an all-out race cam, while the XE230/236 is more of a compromise for better direveability and low-end torque. Not that the 230/236 is bad at all (see the sig).
BRAD
Old Dec 5, 2003 | 05:12 PM
Kreinmc's Avatar
The 306 will beat a 230/236 at the track any day.
Old Dec 5, 2003 | 05:14 PM
FacelessZ's Avatar
Are ya sure about that? It all depends on whether or not you have your heads ported, what else is done to the car, conditions, etc
You win the BIGGEST GENERALIZATION OF THE DAY award
Old Dec 5, 2003 | 05:15 PM
llafro's Avatar
And I'd rather drive my car on the street, since I hardly race it. But I don't want to steal the thread.
BRAD
Old Dec 5, 2003 | 05:25 PM
Kreinmc's Avatar
Think what you want. I have had the 306 with stock heads as my daily driver. 13.0@112.4. and i have shorties. A buddy of mine has the 230/236 on stock heads and runs 13.3@107 with longtubes. I really haven't seen any good numbers from XE cams besides dyno #'s. Even the 305 seems to be a better cam. jmho though
Old Dec 5, 2003 | 05:44 PM
Brandon 95 Z28's Avatar
I agree that the 306 seems to be a constant proven performer, and thats why im putting it in this month
Brandon
Old Dec 5, 2003 | 06:40 PM
96ta(nick)'s Avatar
i just put my 306 in. i am waiting on my heads.
Old Dec 5, 2003 | 06:46 PM
FastWhiteTA's Avatar
Yeah I have the 305 (220/230 and .544/.544) and it is a good cam. A good daily driver and makes good power.
But anyway, the 306 is a proven performer. It's a bigger cam, but it has been proven to make good power time and time again. And I think that guy meant with the exact same setup between a 306 and a XE230 , same drivers, etc, the 306 will be quicker.
Old Dec 5, 2003 | 06:47 PM
kcsoz20's Avatar
Thumbs up Here are some numbers for you....
My numbers with 230/236 are in sig. This is with P&P heads. A lot of the guys in the pacific N.W. section have been witness to my many consistant 12.04-8 110-113 mph runs.
Ken
Old Dec 5, 2003 | 07:12 PM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
I've had both the CC306 and now my current 230/236 - but on a 110lsa. The 306 made a lot less torque than the EX down low ~ and across the rest of the powerband, but both peak numbers are about the same. But the CC306 did hold it's peak power a couple hundred RPM higher and I've actually run a better ET at the track w/ the 306 than I have yet w/ the EX cam. Comparably, the 306 got me a 12.02@115mph, while the EX was a 12.14@114mph. Although now I have a rollbar and and few other items adding a little weight to the car.
But now I get to hit the track sometime this winter to go for a new best.
Old Dec 5, 2003 | 09:30 PM
Ok, then whats the next step up from a 306? A custom grind? How do you think my car will act with a 306, LTs, Borla, and 80,000 for mods? I had a older T/A with a bored over 350 and a 280H series cam in it, so I'm kinda understandin how the 306 will feel. Although I always felt like the 280H was too huge for the engine, but that car also had 2.41 for gears so, it never even got going til after 4700 rpm. Then it ****in roared.
Old Dec 5, 2003 | 09:31 PM
Oh and another ?, should the injectors probably be upgraded along with a inline fuel pump upgrade?
