Percy's Dead-Soft Aluminum -OR- Earl's Pressure Master
Old Dec 6, 2003 | 05:54 AM
96 WS6's Avatar
Which one should I get?? I can't get my felpro 1406's to seal and I've already replaced each side once and I torqued and retorqued them until there was no more torquing to be done and ALL my bolts stay in and don't come out but the damn things still leak. Which gasket is better in your opinions? I like the Percy's because it has hooks. If I got the earl's I would have to cut hooks in them because I don't want to remove the first/last bolts...
Thanks.
Old Dec 6, 2003 | 07:37 AM
F Carline 94's Avatar
I am installing SLP shorties for the first time and am trying to make the same decision. Had two people (non-GM gearheads) suggest that the Earls were overhyped. They look like quality units though.
Any thoughts on drilling the need holes in stock metal gaskets? I bought some when I was just fixing an exhaust leak, until I discovered the broken bolt
Still on the fence for header bolts too.
Old Dec 6, 2003 | 02:36 PM
96 WS6's Avatar
I think I'm going to with the Percy's gasket... I had Earl's before and to me they seemed very flimsy. The inserts kept falling out and I could not get the gasket to stay in place.
Old Dec 6, 2003 | 06:39 PM
amean94ta's Avatar
the only thing that sealed mine (tried all) mr gasket copper seal's
Old Dec 6, 2003 | 06:50 PM
Bud M's Avatar
I used Earl's when I put my headers on 2 years ago, no problems
Old Dec 6, 2003 | 10:44 PM
Z95m6's Avatar
I have percy's and would recommend them to everyone.
Old Dec 6, 2003 | 11:21 PM
ltwonz's Avatar
I would say don't use Earl's because when I opened from the package half of them just fell apart. I don't like the material there made of at all.
Old Dec 6, 2003 | 11:24 PM
anaik's Avatar
Not speaking from my own experience, but from what I have read on the board, Percy's is the way to go.
Old Dec 7, 2003 | 12:15 AM
revtime's Avatar
another vote for Mr Gasket Copperseals.
they are kinda expensive but mine have been leak free so far.
Old Dec 7, 2003 | 01:44 AM
96 WS6's Avatar
I've decided on Percy's. Only problem is, I don't know if I need 1" bolts or not... Anybody have insight on this?? I'm about to order 1" inch ARP 12 pt. heads if I need them. I have 3/4" Stage 8's right now.
Old Dec 7, 2003 | 01:48 AM
anaik's Avatar
Get at least 1" bolts. The more tread you have in there, the better they will hold.
Old Dec 7, 2003 | 01:49 AM
revtime's Avatar
I went with 1 inch bolts and I,m glad I did.
Old Dec 7, 2003 | 09:18 AM
Mystic95Z's Avatar
I had the Fel-Pros any they leaked on my SLP shorties. I went with the Earls over two years ago and have been leak free ever since.
-Tony
DirtyDaveW
Dec 1, 2016 05:37 PM
Midnight_Z
Feb 16, 2016 09:36 PM
Rod Bender
May 16, 2015 02:16 PM
4586
Apr 24, 2015 01:03 PM
cmyname1
Feb 19, 2015 08:38 PM
