hole in fire wall for wires??
Old Mar 16, 2003 | 11:02 AM
qwick_trip's Avatar
i am going to be hooking up a lot of things such as n20, gauges, window switch, timing control, etc. where is the best place to run the wires trough do i need to cut a hole or is there already one somewhere. also i have the whole interior out cause i installed a roll bar. so the seats carpet and plastic panels are out. there are holes in the floor with rubber stoppers can i just use those and runthe wires under the car into the engine compartment??
Old Mar 16, 2003 | 11:51 AM
NXz28's Avatar
in my car i drilled a hole a little bit above the clutch pedal...
just to the right of the steering column when looking at it through the engine bay...
Old Mar 16, 2003 | 12:00 PM
FastZinTennessee's Avatar
Yup take a 10mm socket and unbolt the PCM on the passenger side just under the cowl. Wiggle it out of the way, it's kind of a tight fit. Once it's out of the way you'll see a harness that runs through a good size grommet. You can take a razor and cut a small slit in the grommet and run all your wires through. And I mean ALL of them. I've run some crazy sized power wire through there at work Take off the underdash on the passenger side and the kick panel. After you drop the wires through the grommet just reach up behind the glove box and pull through
John
Old Mar 16, 2003 | 03:47 PM
qwick_trip's Avatar
cool ok thanks
Old Mar 16, 2003 | 04:02 PM
Bryan Smith's Avatar
Cool
Definatly agree with everyone else, I currently have a 0 gauge power wire for my amps running through the PCM grommet, if you dont know how thick that is... think heater hose
Noenav
Mar 1, 2019 07:38 AM
Victor Lamb
Aug 26, 2017 02:52 PM
eanhl2004
Apr 4, 2015 12:01 PM
grabbem88
Mar 18, 2015 01:25 PM
Jul 4, 2005 05:00 PM
