gtp heads
Old Mar 15, 2003 | 04:17 PM
stonecoldz's Avatar
gtp heads
HI,
i have gtp stage 2 heads. they have guide plates, but i'm buying the hotcam kit, the rockers in the kit are self aligning, which means i don't need them, if i'm correct, what must i change on the heads to fit these rockers.
thanks
Old Mar 15, 2003 | 05:21 PM
Max 93's Avatar
just remove the guide plates
Old Mar 15, 2003 | 05:41 PM
zhevy-1's Avatar
You can leave the guide plates in. I didn't think it'd matter, would it?
Old Mar 15, 2003 | 06:40 PM
96z's Avatar
96z
No you should make sure you remove the guideplates. If you dont the two may fight each other.
Just unscrew the rocker arm studs and take them off.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Dec 28, 2014 06:20 PM
1LEThumper
Jul 14, 2003 12:45 PM
97 RedSS
Jun 10, 2003 07:58 PM
