Transmission cooler lines leaking on 93
Old Mar 16, 2003 | 09:00 AM
JIMS1999CONVZ28's Avatar
Just like the subject says and I went through the search and got 14 pages on 'leak*'.
I could not find anything on anyone having a problem with a leak at the flare nuts going into the passenger side of the tranny. I have tightened twice but nothing improves, it is a constant drip when I start the car. This tranny was replaced by the previous owner ( a shop did the work) and there are brass fitting in the tranny where the lines go in to it, then the flare nuts go into the brass fittings, is that right?
I have the GM manual, but it does not show much.
I did not see any "O-rings" on the cooler lines, are there?
I am going outside now and drop the tranny to see if I can see what the problem is, I need to install a converter anyway.
Thanks for any help,
Jim
Old Mar 16, 2003 | 09:39 AM
Try some teflon tape on all the fittings.
Old Mar 16, 2003 | 06:27 PM
Thanks Rob,
I am pretty sure it is leaking between the flare on the tubing and the compression nut.
I got everything ready to drop the tranny but 4 of the 6 bolts bellhousing bolts are very tight. I am using about 8 differenty size (lenght) of 3/8" extensions and there flexing too much. I can twist the entire assemby 1/4 turn. I have a friend that has one long 36 inch 1/2" extension, that should do the trick. I am now thinking of using gasket sealer on the flare to nut and then put it back together.
Jim
jackpawt883
Feb 26, 2015 09:04 PM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
blac94Z
Nov 28, 2014 01:53 PM
thenewkid
Nov 27, 2014 09:41 AM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
