need a lil input
Old Mar 16, 2003 | 11:49 AM
GoTopless95Z's Avatar
need a lil input
Are the front shocks on a '95 Z indeed shocks or are they struts? I'm confused because i purchased a set of eibach lowering springs but then i was told that i need a strut in the front...is that true? I went to KYB to look at a set but still unsure of what i need to order. any help is greatly appreciated.
Old Mar 16, 2003 | 11:51 AM
FastZinTennessee's Avatar
I think it's a strut.
Old Mar 16, 2003 | 11:57 AM
if infact the front is a strut...how do i go about putting an eibach spring on it? I've never done anywork with struts so the whole idea is a lil new to me
Old Mar 16, 2003 | 06:22 PM
You have to remove the strut/spring as an assembly. Yes the spring is attached to the strut. You've got to go rent a spring compressor from a local auto parts store, compress the spring and take it off the strut. Then compress the new spring and install it on the strut. It's a lot more complicated than that taking it off, and it's been a while since I've done this so I can't really remember the steps. You might try doing a search for it, there have been quite a few helpful threads.
Old Mar 16, 2003 | 07:03 PM
Mtrhds94Z's Avatar
Fourth gen F body fronts are 'coil over shocks' not struts...
You do need to compress spring to remove tho..
Here's a link to Injuneer Fred's How to on Hal shocks, and Eibach springs, etc... might help you some...
http://members.aol.com/InjuneerZZ/HALEibch.htm
Nayr
Mar 3, 2023 08:34 PM
Ericksd
Jan 20, 2016 06:07 PM
marlar98
Oct 21, 2015 02:02 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
drt
Sep 27, 2015 04:39 PM
