Where can I buy a 4 bolt main block in CA, ASAP?
For a 383, the a standard bore block needs to be bored .030" over. Since this block is already .030" over and needs a clean up, it will be a bit bigger.
On that note, with a 3.75" stroke:
.040 = 385
.060 = 388
Factory four bolt blocks are damn hard to find, but IMHO, they're over-rated. Fitting aftermarket caps requires align boring/honing just like with a two bolt block, so maching costs remain the same.
Or you could just stick with stock caps
.040 = 385
.060 = 388
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
